I need a five digit code to stream movies from Amazon.com to my Sony Bravia KDL-26L5000
SOURCE: Sony Bravia KDL-40W4500 turns off
This can indicate a problem with the high voltage circuits. Since this is a new set, it should still be under warranty. DO NOT open up the unit as that will void the warranty. Return the set or request warranty service. Note the 8 blinks when you request service as that should allow them to bring the correct replacement parts.
Keep us posted.
Dan
SOURCE: Sony Bravia KDL-46V4000 tuned to digital mode has
YOU LIVE IN A BAD RECEPTION AREA WHERE DIGITAL IS NOT WORKING WELL......
LOOKS LIKE U HAVE TO SWITCH TO ANALOG.....
UNTIL THIS PROBLEM IS SOLVED IN UR AREA.....
SOURCE: My Sony Bravia KDL-40D3000 no longer responds to
Remote sensor seems bad in your KDL-40D3000 that will be replaced because it is unable to receive remote infra red signals and remote has been tested on other tv and found good.
Please replace remote sensor in tv to get it fixed, local tech will help you to solve this problem.
Thanks.
