Computers & Internet Logo
A
Anonymous Posted on Jul 15, 2012
Quarkxpress 9.3: error code 16
Can't open document that I was working on
5 Related Answers
Anonymous
  • 108 Answers
  • Posted on Jun 30, 2008
SOURCE: 6.52 KERN_PROTECTION_FAILURE
Please let me know when exactly does QuarkXPress crashes
Anonymous
  • 108 Answers
  • Posted on Jun 16, 2009
SOURCE: QuarkXpress 4.1 Error Code 88
Are you working on Mac machine or a windows one?
Anonymous
  • Posted on Jul 05, 2009
SOURCE: quarkxpress 6.5 installed in Vista: won't open:
Alas, your only solution is to upgrade to XP and treat Vista like Terminator 3, like it didn't happen. I'm even hearing people say that the latest version doesn't work well unless it's on an XP. I understand that Microsoft was going to address some of the vast incompatibility problems it had created with Vista, but until I see it, I won't believe it. XP is still the best OS going, in my mind. If I was just starting now, hell, I might even consider a Mac. I just have too much software for the PC, plus I still think it's a better OS. It's just that it's aging and Microsoft has shown it doesn't regard its customers as anything but dwebes who need protecting from themselves.
keithkalish
Keith Kalish
  • 146 Answers
  • Posted on Sep 21, 2009
SOURCE: "this document cannot be opened by this version ofQx" (17)
As time goes on software applications tend to change enough that an older version produced file is not forward compatible with a new version. For instance some of my MS Office files no longer can be opened by the latestr version of "Word", hence Microsoft issued a plug in that will allow you older "Doc " files to be read by the latest version of "Word", same thing holds tru for FLASH program, every time a new version of FLASH comes out, the older version can not be read by it.
You need a version of QuarkXpress that can read this doc, If you created the original document, the you can go to your version of QuarkXpress to open the document or if possible ask the originator of the document what version they used to create the document.
Jim Thomson
  • 1099 Answers
  • Posted on Jan 21, 2011
SOURCE: I am using QuarkXpress 6.5
It could be that your quark preferences have corrupted, I would go to your users folder then go into the library folder, then the preferences folder and then the quark folder within the quark folder there should be a file called "XPress Preferences.prf" move this to the trash (But do not delete it yet). When you open quark next it will recreate the preference file and hopefully that will sort it out. If this has corrected the problem you can then deleted the file in the trash. Please note that you will have to reset your preferences once you open Quark again.
Hope this helps.
How do I convert a QuarkXpress 5 document to QuarkXpress 10?
Quark has a free document converter on their Web site which will convert a QuarkXPress 5 file into a format that can be opened directly by QuarkXPress 10. Basically any QuarkXPress documents older then version 7 can be run through this converter to make them compatible with version 10.
I am trying to open a document in quarkxpress and I get the error I/O ( -36). Can you help?
try to open it on a different machine.
it might have also gone corrupted, there is a utility called markzware which can repair such document.
1helpful
Want to convert Quark 7.3 file to Quark 4.1 so it can be read by InDesign.
Thats not possible.
QuarkXPress 7 would allow you to downsave to a QuarkXPress 6 document but not to QuarkXPress 4.
you would have to open the document in QuarkXPress 6 then save to version 5, then open the same in QuarkXPress 5 and then downsave to 4
2answers
Sep 21, 2009 • QuarkXPress
Can't open Book files in Quark 6.5 Mac
Try opening the book first and then the chapters and it should work fine
May 21, 2009 • QuarkXPress
1helpful
I have a msg error code Quarkxpress 7
Sorry I only just saw your posst so this may be far too late, but at least for future reference: -36 is one of the oldest and most ubiquitous errors in the Mac world.
It's name is "ioErr" and the rather obtuse explanation for it is "I/O error (bummers)" ie, there was some kind of input/output error.
This should mean that XPress is trying to work with a corrupt file.
The most likely suspects, in rough order, are a text or picture file that XPress just tried to import; an auxiliary file such as a font, profile or XPress Xtension; a text or picture file already imported; the XPress document you are working with; your XPress Preferences file; XPress itself.
Working with XPress since version 2 on Apple system 6 I have never seen any guaranteed cure for a -36 error but there are three basic remedies, none of which is by any means certain.
Any corrupt file just might be revived by Copying it to another location.
If the file seems to be an XPress document and can be Opened at all, there is a better chance of reviving it by first making a new, blank XPress document containing nothing more than the one obligatory blank pagewith the same page size as the suspect had. Saving, Closing and re-Opening the blank document alongside the suspect, setting both documents to Thumbnails view then manually Dragging each page from the suspect into the blank will essentially cause XPress to look at what it's doing, rather than assuming that all the components are workable. Fairly obviously, it may be safer to Drag one page at a time Saving, Closing and re-Opening the "rescue" file between Drags.
Again if the file seems to be an XPress document and can be Opened at all, there is a better chance of reviving it by working with a Copy, deleting either half of its contents - whether whole pages or items on a single page - Saving the remainder, Closing re-Opening, testing and perhaps again deleting half the contents…
Good luck
Mar 31, 2009 • QuarkXPress
Saving a document file in QuarkXpress 6.0
Just downsave the project by going to File>>Export layout as project and choose the version as QuarkXPress 5.
once done open in QuarkXPress 6 and save it
May 28, 2008 • QuarkXPress
3helpful
3answers
Quark 6.5 Error code -39 in a Mac platform
in this case try creating a preferences folder under the HDD>>Applications>>quarkXPress 6.x folder and then check the results.
if it still continues then try to downsave the document to version 5 by doing a file>>save as and changing the version to 5 from there
Feb 05, 2008 • QuarkXPress
Top Quark Computers & Internet Experts
 Grubhead
Grubhead
goneforever.
ADMIN Eric
ADMIN Eric
Are you a Quark Computer and Internet Expert? Answer questions, earn points and help others
