Sony FD Trinitron WEGA KD-36FS130 36" TV Logo
Anonymous Posted on Jul 16, 2012
What is the location of the main fuse in a sony KD-36FS130 tv?
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Jul 16, 2012
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15004747
Points
237762
Check for it at its main power supply regulator section.
3 Related Answers
jerryg50
Jerry Greenberg
  • 1691 Answers
  • Posted on Apr 19, 2008
SOURCE: KD-36FS130 Digital Set-Up?
I did not know that the Sony FS series has digital capability. This is supposed to be the most basic model of CRT flat screen TV that Sony made.
You can get a digital cable or satellite box that outputs analog baseband or component analog video and analog audio. You can then connect this box in to the TV set. The TV will then display the analog signal from the digital box.
If your cable or sat box is able to tune in standard channels, but cannot tune in the ones that are on digital service, then the fault is with the box, or the cable or sat system. This you should address to the TV service provider.
Jerry G.
jerryg50
Jerry Greenberg
  • 1691 Answers
  • Posted on Jul 22, 2008
SOURCE: help KD-36FS130
components failing in the scan amplifiers and or power supply areas.
Jerry G.
Anonymous
  • 93 Answers
  • Posted on Aug 27, 2009
SOURCE: my sony trinitron KD-36FS130 will not do anything.
All you have to do is to check if the unit is properly plug to ac outlet,and there is a presence of AC,to check you must plug other appliance to confirm,check if there is no cut wire on the ac cord of your tv,the unit was turned on?,if everything is okay,you must call a repairman.You must state your knowledge in repairs so that I can make solutions like troubleshooting.
Tips for possible problem, try to listen the "chechk" sound when you plug the unit, a sign of power supply start up,that means the power supply is working,if that sound repeat at 2 times /sec. the power supply is overloaded,if no sound at all, the power supply is in trouble.
Sony 36fs130 picture red , no green
There are two adjustments for the guns on those old tube type sets.
IT does not star
Check the fuse inside and then have some qualified tech give you an estimate (heavy TV set).
Our TV whiel watching has a blank screen the comes
needs screen adjustment. knob located on flyback transformer
17helpful
Green symbol AV2 won't go away! Sony Trinitron KD-28DL11U
You need to have original Sony TV remote and press Display button on it, on-screen display will disappear.
Help KD-36FS130
Jerry G.
Jerry G.
Powers on but no sound & no picture
If you power the TV set ON, count how many times the light on the front blinks?
Is very unlikely you have to replace the whole main board.
2answers
36FS130 No picture
The best place to begin is the jungle IC. Replace w/cheap generic for test only==works? Replace W/expensive SONY IC. Also suspect,Vertical o/p IC. Please let me know your progress.
2answers
Tv wont turn on
check if the main fuse blew up. good luck!
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
