HI, you must be the person to ask, because I see that you were able to help somoen else with a problem.. My problem is that I keep getting the error message that my USB cord is not connected, when it is and it's turned on. I loaded the software, the patch and it still will not work.. Can you help me before I throw this machine out the window!! lol thank so much! r
There may be a small "DRIVER" needed for the computer to "see" the sewing machine (*make sure machine is turned on!) when the cable is hooked up. (*could be a bad cable try another they are $2 at fry's) This sometimes requires more computer work to make sure the usb cable is connecting the embroidery machine to the computer correctly.
This driver may be located on your Singer Futura Disk? this is not your program to run the singer machine but the one to connect the two so they can communicate embroidery designs and such.
Deep breaths it will never work if it goes out any window.
Cheers,
Embroidery Services
San Diego, CA
SOURCE: please help
I have the CD, but have just posted a message about the driver not working in the install. So, if you want, I can try to send you a copy, but it's not sure it'll work...
SOURCE: Futura CE-200 Software fails to initialize on XP sp2
Maybe you should try to contact singer south africa and ask them whats wrong, my laptop did the excact same thing switch over to home pc and no problem ever again.
SOURCE: I have a Quantum Futura CE-200 and my computer
You need to look for the drivers on the site and download it to the futura program, if one driver is not loaded correctly your program might stop while you are embroadering of might not work at all.
SOURCE: I have a Singer Futura CE-150 and it keeps
Either upper thread is not passing through thread sensor area or sensor is broken.
Second possible reason is that if design is not optimized the sporadic speed change provides thread breakage error even if the thread is not broken physically. Make sure your software is updated to optimize it automatically (Futura main menu->Help->Live Update).
SOURCE: For Singer Futura CE 250. New laptop with windows 7?
Update with WIndow 7 support is already available at:
http://www.futura-support.com/downloads/ce150.html
If you applied wrong patches you will have to uninstall Futura, reboot, install from the beginning the basic version and then apply an update 3.0.0.9
