Its old, its mine, and I still love it but it needs a real good cleaning and the ink absorber is probably full. It needs another new printhead (3rd), I need to clean out the hair and lint mixed with ink build up inside. I hope that will help it last for another many years. Thank you Danbob
SOURCE: Waste ink absorber on canon iP 1600
For Canon ip1000 and ip1600, maybe others
1. remove cartridges
2. unplug AC power
3. hold power button and plug AC power (keep holding power button.
4. press resume 4 times
The waste ink counter should be reset by now
Or
http://www.servicemanuals.ru/download/canon/ip1600.htm
SOURCE: waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
SOURCE: waste ink absorber is full
Hi!
The printer counts every single droplet ejected by the print head due to waste ink absorber capacity. When the waste ink counter rise to about 90 % the printer shows message 'Waste Ink Absorber Near Full'; in this stage we can still continue printing by pressing Resume button until waste ink absorber capacity reach 100% and 'Waste Ink Absorber is Full' appears.
To fix this problem you have to reset waste ink counter to 0%. Even though we can just reset waste ink counter without resetting waste ink counter, it strongly recommended that you replace waste ink absorber to prevent ink flooding inside the printer.
To reset waste ink counter, perform the following steps:
In this stage your printer has operated as usual.
Regards,
SOURCE: I keep getting an error message that the waste ink
Reset Printer Canon MP140, MP160, MP180, MP210, MP220, MP460, MP470, MP500, MP510, MP530, MP600, MP610, MP800, MP820, MP810, MP830, MP960, MP970
SOURCE: how do i empty waste ink absorber
Hi
You can try this I found.
Reset Procedures for Canon i9100 Printers
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
The print heads inside your Canon printer can become clogged and dirty over time, both from dried ink and dust particles. Each Canon printer includes a self-cleaning utility that automatically brushes off excess ink. While the feature keeps your printer running smoothly, it also fills up the foam ink absorber inside the printer. When the absorber is full, your printer displays an error message and won't print. To fix the issue, you need to clean out the absorber and reset the printer's ink absorber code.
Difficulty: Moderate
Instructions
Things You'll Need:
Grab the plastic lid at the middle of the Canon printer and lift upward so the printer's internal compartment is visible. Wait five seconds for the ink carriage to slide over from the right side of the printer.
Locate the square rubber frame at the far right end of the printer that houses the ink absorber. Grip the frame and pull it slightly toward you until it detaches from the printer. Pull the frame to the left and lift it out of the printer. Unplug the printer's power cable.
Pull the two foam ink absorber segments out of the rubber frame. Place all three pieces in a bowl filled with warm water and soap. Gently scrub each piece to release the absorbed ink.
Dry off the two foam ink absorber segments and the rubber frame. Set them on a paper towel and wait for each component to completely dry. Slide the foam ink absorber segments back into the rubber frame.
Position the rubber frame back inside the right side of the printer. Press the frame onto its seat until it locks into place. Push closed the plastic lid.
Hold down the power button on the printer's control panel as you plug in the power cable. Release the power button and wait five seconds. Tap the power button again to reset the printer's ink absorber code.
