SOURCE: Duet Front load Washer - will not start cycle.
Does your front washer, every time you press cancel give you a code that looks similiar to ER?
I checked the description and for some reason whirlpool denies having a F22 code on the Duet, but that doesn't mean much.
I am suspecting several things.
1. Electrical supply may have had a surge at one point or another. You may have to ask your electrical company to put a surge protector on your house by the meter. This is not to protect everything it has its own limits!
2. Unplug the machine for a while. Turn off the water supply and disconnect hoses The machine knows if there is water coming into the machine by a trip sensor.
3. drain out your exhaust line. There is a possiblity your machine thinks you are full of water when it is actually empty.
4 put everything back on, and then plug machine back in after about an hour or so. If it still doesn't work, it is time for your local appliance repair service technician to come out. He will check door trip sensor, and a few other areas that may be acting up.
Good luck.
SOURCE: F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
SOURCE: F 22 front door locked and door won't open.
hi there,
the F22 stands for the CCU/Touchpad error. in other words, the keypad has lost connection with the control board behind it.
this is what you do:
unplug the washer
take off the console
check the connection between the touch pad and the CCU boad
make sure that nothing looks corroded or burnt
make sure that nothing is pinched or bent
unplug and replug wiring harness and connections form keypad to the CCU board
let me know if it this works.
SOURCE: WFW9200SQA12 F22 code problem
The problem you are experiencing is a Long Drain error. You need to check the drain pump reservoir and drain lines for obstructions. the following link explains how:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
If cleaning the pump does not correct the problem, it is recommended by the manufacturer that you replace it. It does not take much to permanently damage these small pumps. If anything has been lodged in the intake if the pump for any significant period of time, the motor and/or impeller may become damaged. This results in a pump they "appears" to be running, but may not be pumping anything.
In addition, check the drain hose that runs from the bottom of the wash tub to the intake side of the drain pump. I have personally found small articles of clothing lodged in this area blocking the drain pump. Garments bags are highly recommended for small articles to prevent this.
I hope you find this information helpful. if you require additional assistance, please let me know.
SOURCE: F22 code door locked
Push the 'end of cycle' button for 3 seconds and that will unlock your machine.
