Will only brew a half cup even when full cup button is pushed
There may be an adjustnent that allows more water to flow in the same ammount of brew time!
Mine started off this way, then quit running any water through. I overcame the problem with a reusable K-cup. They are available online and at some national chain stores for about $15.00. It's a little more inconvenient than K-cups, but better than throwing out a $150 coffee maker.
I had the exact same problem with my machine making 1 cup at a time.
Here is the solution:
1. make solution of 1 part vinegar & 2 parts water.
2. pour solution into resivoir and set for 2 hours
3. run solution through machine (yes, you will have to stand there and keep pushing the buttons).
4. take same solution (now very hot) and run it through machine 5 or 6 times
5. make fresh solution and continue process until machine runs full cycle.
We have four of these machines and none will serve a full cup.
The water seems to recycle back into the reservoir. Just a lot of noise - very little tea/coffee. Surely, this is a common problem - the odds of having it occur four times are just too long.
Same thing mine started producing half a cup regardless of wich size was selected
Mine does the same thing, it used to brew full cups and over time got less and less, now barely fills half of a small coffee cup. And the noise just gets worse and worse.
Oster BVSTKG5-033 only brews half a cup
next cup is a full cup
will not make a full cup
keurig is not brewing the full size cup
