SOURCE: KRAZR K1m STUCK WITH A NON STOP PROBLEM PHONE HELP!!!
Here's a suggested fix. It worked on my K1m. Maybe it will work on yours.
First off, get the latest version of Motorola Software Update.
Then, put the phone in bootloader mode by pressing and holding the * and # buttons while the phone is off and then turn it on while you remain holding the * and # buttons. If the bootloader starts, you'll see a motorola logo on a blue background.
Once you have that screen, plug the phone into your PC with the usb cable, open and run Motorola Software Update.
It should run through the update process and fix the problem.
SOURCE: Blank or White screen on new Motorola Krzr k1 cell phone
the white screen is because the 'flex' is broken. u need to change it. the 'flex' is a part that connects the upper part ( screen) and the lower part (keypad) of the cellphone. the flex is a common problem with flipflop phones. i dont know if u can get it in your country, but we have lots here. it costs around $14-15 including labor.
i was able to solve the white screen problem, but one of the 2 problems w this cell still exists. Whenever i close the flipflop, "memory card removed' appears, and it keeps blinking. Or when i charge my cell, this msg also appears. this also drains my batt. If i reinsert my memory card, it solves the problem, but whenver i charge my cell, it appears again. So its kind of a hassle to always open the back of the cell to reinsert the memory card, so what i do is , i never close the flipflop. Anyone has the same problem?
SOURCE: Motorola rokr e8 speaker stopped working
the media finder in my moto rokr E8 is messed up. It suddenly has stopped detecting my music and picture files that are already in the phone/card memory. I cannot take new pictures and save them... every time I snap a new pic. the phone hangs for a while.
SOURCE: motorola rokr e8 error message
not even a MASTER RESET will resolve this issue most of the time. the only way to fix it is to perform a MASTER CLEAR. Before doing a master clear, make sure you save all contacts to your sim card and images, videos, etc to your memory card.
SOURCE: Micro SD card is not recognizing photos and won't transfer info
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
