HP Photosmart 8250 InkJet Printer Logo
Posted on Dec 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ink system failure
I have been given an HP Photosmart 8230 Printer which, though unused for some time, was previously working OK. I have inserted all new ink cartridges but when installed a message appears on the screen - 'ERROR 0xc18a050a Ink system failure - ink system has failed and can no longer print. I have been told to do a 'cold reset' to see if that fixes the problem. How do I do that, or is there any other way I can get the printer working?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 05, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1932
Points
I had exactly the same problem with my HP 8230 and tried all the posted sugestions with negative results till I stumbled on this site site offering an update for a different problem but added " also clears many ink system failure messages " I downloaded and installed the update and the printer burst into life and now works perfectly, which proves mine was a software problem not a hardware one. give it a try you might get lucky.
http://www.birseyindir.net/driver/HP_Photosmart_8230__Print___12760.html
Alan
Anonymous
Level 2:
  • Expert 58 Answers
  • Posted on Dec 11, 2008
Anonymous
Expert
Level 2:
Answers
58
Questions
0
Helped
15880
Points
181
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
  • Anonymous Jul 17, 2012
    This absolutely DOES NOT work on the HP Photosmart 8250, because remvoving the cartridges and closing the lid will never prompt one to install - or re-install the cartridges. And one cannot close the lid minus the cartridges unless you snap the holders back into place. And when one repowers the printer they will always get a message that they have cartridge failure, because there are no cartridges installed. So try it on your same printer with same error before you go rattling off what others should do. You obviously don't have this printer and those instructions, which I've seen, were written for another model HP printer.
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Jan 02, 2009
Anonymous
Contributor
Level 1:
Answers
20
Questions
0
Helped
83082
Points
44
Ink system failures is a very serious problem on HP printer systems. If you have this problem you should be ready to replace your printer. However there are still troubleshooting steps that you can do to try to resolve this problem. try this Ink System Failure Trouble shooting guide.
How do I fix ink system failure error message on a hp photosmart c8180 even though I have replaced all cartridges. Need to rest the system any ideas?
i love google.... usually:
http://h30434.www3.hp.com/t5/Other-Printing-Questions/Photosmart-C8180-Ink-System-Failure-Error-0xc-18a0005/td-p/331285
If you need further help, I’m available over the phone at https://www.6ya.com/expert/robert_beef7390c57fac0d
I have HP photosmart 321 all in one and I have
here.. check this out. a solution to your problem.
These are reset instructions designed to clear most of hp errors starting with 0xc...It works on different hp models.. it could work on you too.
Semi reset
1. While your printer is on.. unplug to power cable from the printer.
2. Press and hold the "OK" and "HELP" buttons while you plug the power cable at the back of the printer. Try these steps to reset your printer to default setting.
Full reset
1. Press & hold " * " key...(asterisk sign)
2. While holding the " * ", press "#" key and then release both keys..."Enter Special Key Combo" will be displayed...
3. Press "1", "2" and "3" to display Support...
4 Press ">" right arrow button and release when System Config Menu appear....then click OK
5. Press arrow key to display Hardware Failure Status...click OK....
6. When Hardware Failure Status:Clear appeared, press "OK" to clear...
7. Press "OK" again to display "Hardware Failure Status Cleared. Press Cancel To Continue".....
8. Press "CANCEL" as many times to display "Welcome To Photosmart Express" or "Ink System Failure".....
9. The last part is to turn off the printer and unplug at the back...wait for 30 sec, then plug and turn on the printer...if asked, press "OK" to continue and allow the "One Time Ink Initialization" to proceed..After this try to print...
If you find the reset solutions helpful...Please rate this solution and vote YES ..thanks..
114helpful
4answers
HP Photosmart C8180 - Ink System Failure - Oxc18a0101
i had exactly this error message. Rang HP. They said it was a hardware failure, they couldn't fix over phone, would cost 2x cost of new printer to fix, but they offered me 20% discount on new printer if ordered over the phone.
But with some fiddling, problem now resolved. Here's what I did:
- press Red Eye Removal and Print Photos button together
- goes to Mfg Commands -> Enter Special Keys Combo. Press OK
- uaiux Support page (some code) -> click right arrow key until you get to System Configuration Menu - click oK
- should say hardware failure status - click OK
- says hardware failure status: Clear. Press OK to clear
- I clicked OK on this and system reset itself and problem was solved
3helpful
2answers
HP Photosmart C6180 Ink System Failure
The ink system failure message has a chance to be fixed or it may be a permanent issue. It can be pointing toward a firmware failure in the printer and if that is the case the following steps should fix it. Press and hold the ?*? key. Press the ?#? key and release both keys. Display should say ?Enter Special Key Combo? Press and release in sequence the "1?, ?2? and ?3? buttons. Display should say ?Support? and display the FW rev (something like R0631R) Mine reads R0631M . Press and release the right arrow button until the display says ?System Configuration Menu?. Press and release the ?OK? button. Display should say ?Hardware failure status?. If not there already, Arrow Key over to ?Hardware failure status?, Press and release the ?OK? button. Display should say ?Hardware failure status: Clear. Press OK to clear?. Press and release the ?OK? Button. Message changes to ?Hardware failure status Cleared. Press Cancel to continue?. Press and release the ?CANCEL? button as many times as necessary, so that, either the ?Welcome to Photosmart Express? screen appears, or, the ?Ink System Failure? screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer. Turn the unit on. The printer may display message ?USE POWER BUTTON TO SHUTDOWN THE PRINTER? followed by ?PRESS OK TO CONTINUE?. Press OK. The Printer will start the ?ONE TIME INK INITIALIZATION PROCESS?. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. Good Luck!
2helpful
HP Photosmart C5180 will not read new ink cartridge
With reference to Expert Burti, he has given the solution to your problem.
"Just got off the phone to HP and the issue is resolved *phew*. This waswhat I was told to do for my C5180. First they told me to do a powerdrain. This is done by pulling out the power cable and then holding theon/off button for a minute, then putting the power cable back in (this didn't work).
Then we did a master reset. Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. This sorted it. :
Have to say it looked like this whole process used up shed loads ofink, so by the time I had finished I needed to replace 3 cartridges!
HP were pretty good and were very willing to send out a new printer if the reset didn't work (as the printer is still in warrenty). Hope you get yours sorted too."
With thanks from expert Burti.
1helpful
3answers
HP photosmart 6188 Ink Failiure System
Not sure how to help you. Ink failure I would think is cartridge failure. Are you original virgin cartridges or refills? I need the actual error message that the printer is giving.
11helpful
Ink system has failed. Error:0xc18a0001 my printer is HP Photosmart C6280 All-in-One i have an Error massage (Ink System Failure)it says: ink system has failed. unable to print. refer to printer...
ok i got it...
Press and Hold the “Print Photos” &”Red Eye Removal” buttons. Release both buttons. Display should say”Enter Special Key Combo”
Press and release in sequence”Red Eye Removal”,”Print Photos”,”Red Eye Removal”
Display should say “Support” and display the FW rev: COxxFN0723BR (or something like that)
Press and release the right arrow button until the display says “System Configuration Menu"
Press and release the “OK” button.
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
the printer will get ready as if it were starting perfectly for a first time, it will say something like: printer preparation occuring - do not interrupt
print a test page:
1) Load letter, A4, or legal unused plain, white paper into the input tray.
2) Make sure that the printer is on and loaded with unused plain, white paper.
3) Press Setup . The Setup menu appears.
4) Press the down arrow button to select Tools , and then press OK .
5) Press the down arrow button to select Self-test Report , and press OK . The self-test report prints.
if this doesn't work, i'd call hp support.
20helpful
6answers
Ink system failure
ok i got it...
print a test page:
k24674
Grand Canyon Tech
Grand Canyon Tech
