Recently filled IX35 hows warning for low fuel. Impossible as only traveled 5kn since filling Any ideas
SOURCE: rattling sound in rear of
your rear number plate can be loose or one of the rear wheel bearing is making the sound
1. tap the number plate and see if it sounds
2. jack up the rear wheels one by one rotate as fast as you can with your hands you will feel the sound
3. take it to a garage if this does not work
SOURCE: i thinking of buying a
Most manufactures recommend 50,000 to 60,000 miles. They do last a lot longer than this though.
SOURCE: my 4 week old Hyundai ix35's panoramic sunroof
Give me some more information about this problem. May be i can help.
SOURCE: Hi there, My Hyundai ix35 has the bluetooth
Nice & easy- Have your radio switched on. Push & hold the volume knob for 3 seconds. It should now say Initial volume setting (or something of the like), scroll to the right & it should say clock setting, press the volume knob again. Turn the knob to change the hour figure, press the volume knob again for minutes and press the knob again to set.
Hope that this helps
SOURCE: How to set base and treb settings permanately as
sounds like a wiring issue mostly seen on aftermarket audio setups. memory relative equipment must be wired into "ignition" power and not straight to the batt. aftermarket or stock radio/stereo?
