Nocko pradika try to do factory reset by settings, it will solve your problem, if problem persist post comments for further help, if my answer was helpful please rate it, and Thanks for visiting Fixya.com. Best of Luck.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Be sure your mode dial is not in the auto position. If it is, the camera will only function with the lense also locked to the auto position, which will either be the lowest aperture (highest number) or sometimes an "A" setting separate from the normal aperture settings. That's generally what this type of indication means on program/manual models - that you're trying to use manual settings, when the camera is set up for auto program exposure.
what are facing is a problem caused by a virus that either destroys files that support .exe applications to run or it replaces which makes your machine unstable. my first solution to you is to repair your operating system using the operating system cd. secondly, if that doesn't work please try installing a second os on your system and then you do a dual booting. u then delete the folder of the previous os. if that does not work u backup ur files and then you format ur system with a new os
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
i think
Game is to heavy for your computer to run
Might need more free memory or your sound & Graphic card are not supporting this game. Before you download any aplication from any website make sure your computer meets the reguirements, Such as Operating system, sound and Graphic card and make sure you have enough Ram space to run the software.
U need to replace your USB. I replace it four times, the problem is that when we try to connected we for-set so the thine wires get damage.
sorry but you need to Repairs your USB
don't worry is only 6.00 in ebay.com
copy n paste this
