I though I had a faulty unit so I exchanged for another of the same model... same problem. Unit locks up as if the protection circuitry has been activated. Checked troubleshooting, my difinitive tech. speakers (3 total.. 2 front(studiomoniter350 and a sub (super cube)) are hooked up correctly, no wires are touching, tried both impedence options. Tried different speaker wires, have a nice surge protecter.. I can get it to have sound but its locked and If I press any button it locks.... Somebody help me I'm losing my mind!
SOURCE: Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVERS MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than 3 SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers dont have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
SOURCE: yamaha rx-v661 unsolved speaker wiring error
1. Try running the auto setup without the sub. ( is it a powered sub {the sub has its own amp on the back} or is a NON powered sub that is driven off the speaker jacks of the Yamaha receiver. )
If the sub is powered, and connected to the Amp via the RCA cable from the " sub out " jack, chances are you either have a defective sub or a gound loop.
Good luck...Rob
SOURCE: auto protect
that is actually a sign that the reciever is bad. it usually means the amp is blown. Not in the sense that it wont work. But its overheating and thats where the problem lies. for this recieve it only costs 130 for the pcb board that goes bad. I know no one likes to hear that there stuff is broken. But when i worked for Square Trade i seen a few dozen of these units come through and it was always the amp which can still be serviced by yamaha. -Thanks Nate
SOURCE: Front speakers no sound!
Most likely you have pressed the speaker AB switch, try pressing it again and see if it works.
SOURCE: Yamaha HTR-5760 goes to standby 2 seconds after power on
Maybe your device got the audio amplifier IC damaged
pulse code modulation light blinks and sound goes out.
Yamaha HTR-6130 p.o.s.
I'm so glad (not glad) to see this problem posted. Unit locks up at least once every day. Have not discovered any consistent trigger for this to occur. If it is a flaw that exchanging unit will correct that is a hassle, but at least a solution. For now, I simply unplug and plug back in. Anyone find a cure?
