The paper starts in and then it just stalls there,the unit is running, the light is on ,but the paper does not advance.
Do you think you can help me from this information?
I'd hate to trash it, Never had a problem with it till now.
A.R.Mole
SOURCE: paper wont feed
It's just one of four things............
1. The paper is not loaded correctly on the correct path.
2. The paper is loaded correctly on the correct path but the "PAPER PATH" selected in the printer driver box or printer preference or application used is not set correctly to grab the paper from the correct path.
3. The paper path sensor is defective which means that the printer needs to be taken to a servicer or you need to contact epson for warranty options
4. The paper being used is too thick for the printer to feed it
SOURCE: PSC 1215 - Not feeding paper
Hi
I think the problem is due to some paper picker inside the printer please show it to the service people near you location
T.Boopathy
SOURCE: lexmark X85 Printer
i tried cleaning the rollers off with lens-cloth & paint thinner & got TONS of ink off the rollers, still same problem thoough, but very slight improvement.
SOURCE: Fisher & Paykel top load intermittent running
Check your water pump... When they get wet or leak, they will shut down the machine control. If you wait too long you will blow out your machine control completely. You most likely need a new water pump and it is easy to replace with no tools needed. Your part number is a 420325P and you can get one from Fisher Paykel Parts direct:
http://fisherpaykelparts.net/index.php?categoryid=111&productid=3
SOURCE: canon pc 420 paper feeds only part way
I had the same problem. I found a parts diagram here http://techno-parts.org/canon/220/320_220.php which showed that the springs hold the bar down. On mine, on each side, one of the spring tabs was broken.
I made a metal pin for one side and insert a screw on the other. Be sure and wrap the spring over the nylon bushing.
