LG LD651EBL Dehumidifier Logo
Bill L Posted on Jul 14, 2012
Lg dehumidifier ch 67 error
I keep getting an error of ch 67 on my dehumidifier, lg says could be fan issue, but I saw on here to replace a sensor. Anyone have any updated information?
Bill Hurlburt
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 17, 2013
Bill Hurlburt
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5639
Points
Thanks for the post by Posted by Bill L on Jul 14, 2012.
I decided to take a chance and order the new Sensor assembly $20.50 and install it in my LG LD651EBL Dehumidifier which was giving me ch 67 errors. Wala, it worked, the error code is gone and the dehumidifier is now working perfectly! Thanks
  • 1 more comment
  • Sally McKay
    Sally McKay Nov 01, 2013
    Can you tell me the part number you used to by the replacement part? I have the same problem
  • Bill Hurlburt Nov 02, 2013
    Here is a site to purchase the Sensor Assembly
    http://www.repairclinic.com/LG-Dehumidif... Manufacturer Number 6877A30013V. It worked for me. Good luck.
4 Related Answers
Anonymous
  • 3 Answers
  • Posted on Dec 17, 2008
SOURCE: ch 01
Change the sensor assembly and all will be fine, about $30 from Appliance Factory Parts on line store, about an hour to do, all that is needed is Phillips screw driver to take unit apart.
Anonymous
  • 1543 Answers
  • Posted on Jul 09, 2009
SOURCE: Too much play in an LG demidifier fan
If you are in the USA, you can check for a service provide who could order the part for you at http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp
but when you contact them, make sure you have the full model and serial number. (usually located behind the water collection bucket)
Anonymous
  • 43501 Answers
  • Posted on Jan 27, 2011
SOURCE: I have a LHD 45ELY8 Dehumidifier and it keeps
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Anonymous
  • 43501 Answers
  • Posted on Mar 07, 2011
SOURCE: My LG Dehumidifier has in the Present % field 'CH'
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
heatman101
What does the code 24 and CH mean on my LG dehumidifier?
Hello everyone, can someone please tell me what is error code CH10 on lg dehumidifier please?
Thank you
Code: CH 67
Bucket switch/float valve sticking? Take out the bucket and make sure the switch moves freely.
Error code 67
Error code 67 is an airflow problem. Either clogged filter or bad blower motor. Unplug unit remove bucket and feel for filter in front behind cover it drops down. Clean filter with water and reinsert. Plug unit in turn to "on", fan should begin to run, after 3-5 minutes compressor should start. If fan does not start it is bad and should be replaced.
3helpful
2answers
LG dehumidifier LD451EGL with error code CH67
After cleaning the filter, i had to unplug the unit to clear the ch 67 error code before the unit would run again.
6helpful
5answers
Error message CH 24. Any ideas? I have the LD651EBL dehumidifier.
We;ve managed to clear this error, at least for the last 5 days. Remove the bucket, and reach up behind the front panel where there is a filter- ours was covered in dust. After cleaning this off, and resetting the machine (by pulling the electric plug out and re-inserting), the error went away.
Your mileage may vary.
2answers
Code (CH) (01) on front panel, what does it mean?
I believe it is a water tank code. Re-seat the tank, unplug wait 15 seconds and replug the power cord and see if this resolves the error.
Background relating to other possibilities.
When the water bucket reaches its capacity, the bucket switch opens to shut off the dehumidifier. If the bucket switch fails while it is open, it will prevent the dehumidifier from running. To determine if the bucket switch is defective, use a multimeter to test it for continuity. If the bucket switch does not have continuity, replace it.
36helpful
3answers
Error code on Digital LG Dehumidifier - CH 1
Change the sensor assembly, Part # 6877A30013M from Appliance Factory Parts in Englewood CO, about $30. Easy to change, plugs into control board, remove old temperature probe by pry T-well open with small screwdriver and then crimping back closed when new sensor is installed, about an hour start to finish, hardest part is getting all the covers off. Mine is back to working like new again!!
26helpful
2answers
Ch 01
Top LG Dehumidifiers Experts
ZJ Limited
ZJ Limited
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
