When I bought my compact JigSaw it came with a palm sander. However, my question is does the sander come with a sanding pad already attached? The sanding pad appears to be rubber made?
SOURCE: replace sanding pad on random orbital sander dw443
You will find usually 3 torx drive screws on the bottom of the tool, remove them and the pad comes off. The replacement pad number is 151416-01 list 27.49. Let me know if I can help further
SOURCE: no sanding action and motor just buzzes
It will probably be the shaft from the motor to the orbital cam which is on the flat plate that you connect the sandpaper to , either the shaft or the bottom cam is broken [probably the shaft has snapped ] you can do a cheap repair with a good glue to reconnect the shaft [but you wont be able to push too hard again] or if you can get the parts just replace the shaft into the motor . they are really simple things to work on
SOURCE: I use Dewalt random orbital sanders regularly
The velcro pads wear out and need to be replaced periodically. You can buy new pads on-line at any Dewalt parts seller.
Testimonial: "Thanks much,. I suspected that that was the case but have been unable to find the replacement part. I'll try again."
SOURCE: Where can I get instsructions for the Dewalt DW411
go to Dewaltservicenet.com and in the midle of the page and towards the bottom under need manual type in your model number and you should be able to download anbreakdown and operators manual
SOURCE: I have a Dewalt sander I am using for wet sanding
Impossible not to get water in the bearings and motor. It is vibrating too fast. You need air sander. Or sand dry, then wet sand the primer by hand.
