Display half of screen
I have 17" Compaq S710 crt monitor, when I switch on my desktop monitor shows display almost half of screen a large black strip on upper side and small black strip on bottom, left and right side appear, there is no any line, bright or dark spot on monitor, however display is a little dark and have to adjust manually every time, monitor some time for a second goes black and then restores half display K. Aziz khalid_1k@yahoo.com
    Genius:
  • 2,432 Answers
Screen back light on the other side is busted which need replacement.
Posted on Jul 14, 2012
SOURCE:
  • 124 Answers
SOURCE: ACER 17" black monitor
first, I would check screen cable. try replacing it with a new one, you will be surprised to know how many display problems are are caused by a defected screen cable. in case this is not the problem, it can get more complicated, but first, just in case, reinstall drivers. its a long shot, but if you get lucky it will save you alot of pain. in case it didn't help, It's probably a bad vertical output chip. if you have some familiarity with monitors and decent soldering skills you could probably fix it yourself, but I would advise looking into taking it to a shop, or at least find an experienced hobbiest if you're not yourself. It's a pretty straightforward fix for someone who knows what they're doing. good luck.
Posted on Apr 03, 2006
SOURCE: Hansol 730E CRT monitor
REPLACE THE BOOSTER C 5,6nF-1600V
Posted on Oct 23, 2007
SOURCE: HP mx705 17 in.CRT Conventional Monitor vertical goes bad
it seems that youre monitor has a dry solder problem, try tapping it if the picture resumes to normal for a while than get it resoldered from a technician. if it soesnot solve problem than look out for a burnt resistance.
Posted on Jun 26, 2007
Fix-4U
  • 293 Answers
SOURCE: monitor stops display
Hi...there,
It's seems your LCD Monitor backlight inverter it burnt out. Need a new inverter. Have a nice day!
Posted on Sep 08, 2008
  • 7 Answers
SOURCE: Monitor goes on then off right away.
I concur with "Drikus41". The back light inverter is probably faulty. Or more likely, the circuit board driving the inverter. Seems like a component is heating up quickly right after you turn it on, and it's shutting down the power to the light. If you're adventurous, you could also attempt to check the connection cable inside the screen bezel.
Posted on Jul 17, 2009
Displays the whole desktop in half of the monitor screen
Resolution settings are too high in monitor or computer video settings. Choose Recommended settings.
Mar 30, 2014 | Hansol 730E 17" CRT Monitor
How to Fix display problems ( red display, or only for about 2 seconds display)
There are two problems, screen goes black after 2 seconds, red only. The problem is in the video processing board located on the back of the picture tube, it is well shielded against outside interference.
Apr 07, 2012 | IBM J156-1702 17 in.CRT Conventional...
Compaq FS 7600 - display - CRT - 17" driver
click start control panel you will see thre options change theme change desktop background and adjust screen resolution then select resolution from the drop down list you can adjust to your preffered settings 1024x 768 is usually recomended (you have not stated your problem)
hope this helps
Sep 22, 2011 | HP Compaq FS7600 17" CRT Monitor
Hi, I have compaq 7540 monitor 17''. It is showing only part of the screen and when I shake the monitor or plug it displays full screen for a second and gets reverted. Please help on this issue.
Sounds like you have a bad connection somewhere inside the monitor or cable. Try using a different cable (if possible) or trying a friends monitor. If it works fine, then you know that's your problem. CRT monitors are very inexpensive nowadays, and you might be able to find one at a yard sale or thrift store for pretty cheap instead of trying to get it repaired. Hope this helps!
Aug 25, 2011 | Compaq CV 7500 17" CRT Monitor
LG Studioworks 700S 17" CRT Monitor, on screen
Dear Sir,
This problem is not from monitor side,check computer RAM.Clean it twice and reinstall it on place.If you are using VGA card then disconnect it from PCI slots and connect VGA cable to on board VGA . I think it solves your problem.Let me know
Jan 08, 2011 | LG Studioworks 700S 17" CRT Monitor
My Toshiba p105-s6064 display screen is only showing half of my desktop, the other half goes black or flickers various colors. Do I need to replace the display screen or the video card?
Try connecting to an external monitor if display screen is only showing half of my desktop, the other half goes black or flickershalf of my desktop, the other half goes black or flickers various colors then it is the video card if not....have ur display screen changed.
Nov 10, 2009 | Toshiba Satellite P105-S6064 Notebook
Hp Compaq FS7600 17" monitor screen adjustment needed
Um, lets see. Does any of the buttons work? Try and find a button that will switch settings back to factory default. If not go to control panel and change the screen resolution to see if that helps in the mean time.
Jun 26, 2009 | HP Compaq FS7600 17" CRT Monitor
Bottom half of monitor displays top half of desktop
You could try a different resolution for the monitor.It's possible the monitor cant support the resolution your trying to display your desktop at.
Jun 01, 2009 | ViewSonic GS773 (White) 17" CRT Monitor
Monitor settings
try to adjust with the panel button . bye
Sep 23, 2007 | HP Compaq FS7600 17" CRT Monitor
Monitor switching to standby - CV735 monitor with Presario 5000 series desktop
my compaq crt monitor not showing color. its shows only blue, green colors . u please tell me. what is the problem in.how to solve it.
is the monitor fault or any other.
Oct 30, 2006 | Compaq CV735 17" CRT Monitor
Open Questions:
Computers & Internet Logo
317 people viewed this question
Ekse
Alun Cox
