Question about Amcor PLM 10000EH Portable Air Conditioner
Whee is water pan located?
Where is the water pan located? how do i get to the water pan
    New Friend:
This unit features the patented AutoDrain NanoMist Technology that Vaporizes excess fluid build up, eliminating the need to drain the unit. Most of this water is used to cool the unit and make it run more efficiently. This unit has a built-in water tank (non removable) with a drain outlet for end of season draining and storage purposes
Posted on Jul 14, 2012
SOURCE:
How to drop oil pan 2 whee drive 05 colarado
The best solution you'll get from books at www.reliable-store.com
These are bo oks containing info on repair, service, troubleshooting, parts info, assembling dissemble, removal, error/fault codes, wiring diagrams and everything on any vehicles cars, atv, trucks. forklifts, boats, excavators etc
Jun 15, 2018 | Cars & Trucks
Whee is the water pump located
The V6 model is driven by the timing belt behind the cover. The 4 cyl engine pump is driven by the serpentine belt along with the other accessories.
Jul 20, 2013 | 2007 Chrysler Sebring Sedan
Water leaks on floor, where isthe defrost drain pan? the manual indicates that water might build up in drain pan, the connections with the ice maker are all dry.
The drain pan is usually located closest to the floor - behind the kick space or toe space grill at the bottom of the fridge. Most often the water that collects in it is evaporated by the heat generated by the compressor and airflow from condenser fan located close to the pan.
Make sure the water is coming from the defrost drain hose - not from water sources elsewhere in the fridge (leaking water / melting ice into the fresh food compartment, etc.). If found, take action to correct.
Oct 19, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Leak from refrigerator bottom when dispensing water
Good day,
The water supply starts at the dispenser, runs thru the door to the door's bottom where it connects to a swivel connector.
From there it travels under the machine and back into the fresh food compartment to a reservoir located behind the crispers where it is chilled.
It comes back out and travels to the filter system if you have one, and from there to the water valve located on the back rear of the machine.
One of the plastic lines or a fittings is leaking.
It's a look-see repair. Should be one person drawing water, while a second should be looking with a flashlight.
Nov 20, 2009 | Whirlpool Refrigerators
your evaporator coil sits in the water pan This pan is installed at the bottom of the evaporator coil to prevent condensate water from damaging the area the furnance sits. If you open your furnance and look where you put the a/c filter the coil should be right here. If you look at where the coil rests there is you "water Pan" Good Luck hope this helped
Dave
Sep 17, 2009 | Heating & Cooling
Water is pooling on the floor under the refrigerator
The drain pan is located in the back on top of the compressor. sometimes will develop rust holes. water will be leaking from the pan up
Jun 10, 2009 | Frigidaire FRT18B4A Top Freezer...
Water leaking into the drain pan
if the pan on the compressor on plug unit get a rag and sock up the water i beleave you doors staying open to long
Mar 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Leak in the shower is leaking water through the ceiling
SInce it is wet both under and behind the shower I would rule out the drain floor pan and drain system and think it most likely to be the pipe leaking from the mixing faucets to the shower head. Find studs directly behind shower faucet, n each side. Locate the center of the studs and put vertical lines up and down on the center line of the two studs closes to but outside the shower  faucet on each side. Approximate 6 inches or so  up and down for the height of the shower faucet (Valve, not head) Put Horizontal lines across between the two line at both the top and the bottom/ You now have a square.Using a Razor knife(Sometimes called a box knife, stanley 99a for example) cut into the lines of the square back and forth as deep as you can. Cut an x  acrossthe square corner to corner again as deep as you can . Lightly hit the center of the x until the drywall caves in . Cut the remaining drywall out for the square. Now while  the shower is running you will be able to see whee the leak is. Use pipe seal after disassembling the loose fiting or repair the leak iun what ever manner is necessary. Replace and repair the hole made in the drywall  with another piece of drywall, tape and joint cement. .
Feb 27, 2009 | Home
Kitchen aid refrigerator superba
hi there,
the drain pan is under the fridge behind the kickplate. the kickplate is the vent-line panel located under the door. it's held on by 2 screws. unscrew the screw and remove the kickplate. the drain pan will slide out. careful, as it's probably pretty full.
Oct 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Drain pan leaking?
there is a drip pan located underneath you ref but most likely your prob is a plugged drain line coming from the freezer. when you ref goes into automatic def the water doesnt run out into the drip pan but instead onto your floor..
you can clean the drain line by removing the rear cover in the freezer compartment and using hot water to thaw the drain below the evap coil.
Dec 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
Amcor PLM 10000EH Portable Air Conditioner Logo
156 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
