Controller will only work in ps3 menu and not in game.
SOURCE: pelican pl-2073 xbox blade 2.4 ghz street wireless controller
Are you sure it's a PL-2073? or is it maybe a PL-2047? If it is, here the manual for the PL-2047.
http://www.pelicanperformance.com/support/pdf_manuals/XBOX/PL-2047%20Blade%202.4%20Street%20Manual.pdf
SOURCE: PS3 don't load Main Menu and don't recognize controller
never load the main menu!!!! what i can do??
SOURCE: Ps3 controller won't turn on...
hi..
Hardware problem. Usually the motherboard, sometimes it's the hard drive. You can use a few ideas from this guide:
http://boardsus.playstation.com/playstation/board/message?board.id=ps3&thread.id=3290911
but more than likely you'll have to send the unit into Sony for repair. You can reach them @ 1-800-345-SONY..
thank u
rate me
SOURCE: My pelican adapter from ps2 to ps3 via usb will
could be that the adapter is a 3rd party adapter and that would be it doesn't pass the qualtiy that Sony requires before it puts its stamp of approval on the item which means your taking a chance on the item working.
See if you can find an item that is approved by sony and then try that.
SOURCE: the guide button on my pelican wired controller
You are having a controller board problem I would suggest getting it repaired or replaced or you can take it apart and make sure everything is in working order such as no burnt buttons or melted solder.
Same problem, Logitech W733 stick.
control won't work with ps2 games only at the menu solutions anyone
control won't work with ps2 games just main menu on the ps3
I JUST BOUGHT A PELICAN WIRE CONTOLLER IT WILL WORK ON MENU BUT NOT ON GAME...
