Question about Vtech Cordless 6041 Phone
De-register vtech ds6101 handset
De-register
    New Friend:
  • 3 Answers
Called the manufactuer.... To do this enter on the handset you want to deregister:
*331734# and press (Menu Key# 1 - top uppermost left button that is unmarked).
This will put the handset back into the register mode.
Hope this helps,
James Pavicic Jr
Posted on Sep 08, 2012
  • David Louque
    David Louque Jul 12, 2017
    Code works on DS6121 also. Handset was stuck in connecting mode. Base could not deregister. Thanks
4 Suggested Answers
SOURCE:
SOURCE: My vtech 5825 screen says NOT REGISTERED and does not work
Place the handset in the charger and press find handset for 4 seconds.This will register the handset. do the same for other handsets.
Posted on Sep 20, 2009
SOURCE: How do I deregister my handsets on my VTech 2656
To be able to register your replacement handset, you must de-register all the handsets from the VT2656 base unit.
Follow the steps below to de-register your handset(s) from the VT2656 base:
1. Take out the handset that sits on the base.
2. Unplug power from the base.
3. Hold down PAGE while reconnecting power. When the In Use light blinks, release the PAGE key.
4. Hold down PAGE key for 5 seconds. When the In Use light begins to flash, release the PAGE key.
5. The handset charging light will blink 5 times. Within 5 seconds from when it stops blinking, press PAGE once.
You must register the handset(s) by following the steps below:
1. After charging the handset, remove it from the cradle, the LCD display will read "SEARCHING FOR BASE".
2. Press "NEW" and then enter the 15-digit Base ID code, located on the underside of the VT2656 base unit.
3. Press "OK". The handset will display "PLEASE WAIT!!".
4. Wait approximately 15 seconds. The handset will display "FOUND BASE". If the handset displays "BASE BUSY TRY LATER", this indicates that the system is in use. Wait until the base unit is in the idle (on hook) mode and repeat steps 2-4.
Posted on Jul 14, 2011
  • 1335 Answers
SOURCE: VTECH LS6125-2
The 6125-2 only supports 2 handsets.
Posted on Aug 09, 2009
My V-TECH CS6229-3 phone base does not register the base phone but i can change another phone on this three phone set and it is registered and the phone
Is the handset you are trying to register de-registered? if not it will not register to another base until it is.first de-registered.
To de-register the handset do the following-
With a charged battery in the handset Enter *331734# then without pause Press and Release the Menu Select Button. You will hear a Beep. Handset would then be De-registered..
Then place the handset on the Main Base cradle and follow the instruction that come up on the handset display.if the handset still does not register then most likely the base memory is full and will have to be re-set .
To re-reset the Base:- Remove any handset from the main base cradle. Then Press and Hold the Locator or find HS or handset Locator button until the IN USE light comes on and begin to flash then release it and immediately with out pause press and release it again. That will re-set the base memory. All your handset will then be de-registered and will to be re-registered. Place each handset to be re-registered on the Main Base cradle and follow the instructions on the the handset display and they will register.
Sep 06, 2016 | Lands Phones
HOW DO I DEREGISTER MY BASE STATION?
If you want to replace a handset or re-assign the designated handset number of a registered handset, you must de-register all the handsets and then individually register each handset.
To de-register all handsets:
Press and hold
FIND HANDSET
on the telephone base for about 10
seconds (until the IN USE light on the telephone base turns on and starts to flash), then release FIND HANDSET
Press and release
FIND HANDSET again. (You must press FIND HANDSET
while the IN USE light is still flashing. The IN USE light flashes for
approximately seven seconds.)
All system handsets show
CONNECTING...
The de-registration process
takes about 10 seconds to complete. All handsets show
NOT REGISTERED
when the de-registration completes.
If de-registration fails, you might need to reset the telephone and try again.
To reset:
Pick up the registered handset and then press
/FLASH
Press
OFF/CLEAR
and place the handset back in the telephone base.
-OR-
Unplug the power from the telephone base, then plug it back in.
note:
You cannot de-register a handset if any system handset is in use.
After de-registering, proceed with registering process:
If the handset screen does not show LOW BATTERY
or HANDSET X, you will need to charge the handset for at least five minutes before registering to the telephone base.
To register a handset:
Place the unregistered handset in the telephone base or charger. If
PRESS FIND HS 4 SEC ON BASE
does not appear on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
On the telephone base, press and hold
FIND HANDSET
for about four seconds (until the red IN USE light on the telephone base turns on) and then release the button. The handset shows
PLEASE WAIT...
and it takes about 10 seconds to complete the registration. The handset shows
HANDSET X REGISTERED
(X represents the handset number assigned)
and you hear a beep when the registration completes.
Nov 13, 2017 | Lands Phones
Panasonic Phone Keeps De-Registering
This solution is for the KX-TG2356 cordless phone
The problem you are having is not that the handset is de-registering but your handset is losing the link to the main base.You said you went through 6 handsets then, the only remaining thing that could cause your problem is: A bad handset battery. This would give you all types of connection problems and the Main base.
I will begin with replacing the battery. If that does not solve your problem then the problem would be the main base
Mar 24, 2017 | Panasonic KX-TG2356 Cordless Phone
How do I deregister my kindle
I have changed the account on the fire hd many times when My Grandma let my mom borrow it. Just go to your Kindle and swipe down the tool bar. Then click "More" and then "My account" and then "De register". You should be able to then register a new user.
Jan 08, 2013 | Amazon Kindle Fire HD
Apr 30, 2010 | Vtech Digital Cordless Telephone VT-2568
I need to deregister missing handset #1
To de-register HANDSET #1:
1) Grab any working handset which is registered to your base (so HANDSET #2 or #3 in your case)
2) Press and hold the "END" + "#" key for 5+ seconds (wait for it to beep)
3) Choose the "Deregister HS" menu option
4) Pick HANDSET #1 as the handset ot de-register (since that's the "phantom" registered handset)
5) Once de-registered, you can de-register handsets #2 and #3 directly from each handset's "normal" menu interface (i.e. press "Menu", choose "Deregistration")
6) Thereafter, if you re-register your handset, they should start at HANDSET #1, then #2, and so on.
Aug 27, 2009 | Uniden TRU8866 Cordless Phone
Restting the phone handset number
I would suspect that you need to de-register both 3 and 4 at the same time before re-registering them. This probably will not work if the base unit still thinks phone number 2 is out there somewhere. It would need to be de-registered as well for the others to move up a notch. I did read the process for de-registering somewhere on the web, don't remember where, just that it involves removing/installing the battery and punching some buttons.
Jul 28, 2007 | Panasonic KX TG1000N Cordless Phone
Vtech Cordless 6041 Phone Logo
1,015 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
