Sound just suddenly went out while we were watching tv. Checked all connections and we get nothing.
SOURCE: No sound from my Samsung 40" flat screen tv
probably your cable or sat box malfunctioned. try unplugging the power for 2 minutes and then plugging it back in. my cablebox would do that to me all the time. let me know if this doesn't help. check sound on dvd or other sources to narrow that down.
SOURCE: 46" Samsung LCD, no sound output whatsoever
First try hooking up a different source such as a DVD player or Cable box and see if you have audio. If you do then check the audio output from the computer. If you do not have audio then make sure the tv audio is up half way and turn off the set. When you do this you should hear the down chime provided you have the chime turned "on". If you do not hear the down or up chime then the sudio circuits on the Main bd are bad and the Main bd will have to be replaced. A quick way to check to see if the audio circuits are working is to listen for the up or down chime when turning on of off the set coming from the tv speakers speakers.
SOURCE: Samsung PPM50H3
this is indication of protecion short in a integrated circuit to take a few seconds to sense. Please send to recommended service center.
SOURCE: No audio on my samsung FPT5084
cHECK IF THE VOLUME IS IN THE MUTE STATUS TRY TO CHECK THE CONTROL
SOURCE: I have a Samsung LN-T1953H TV and the sound
It sounds like the main board has gone out. The only audio components are the main board, wiring and speakers. Since audio is missing from external speakers as well, that tells you that the main board is at fault. The cost of the board could be from $150.00 to almost $300.00 depending on the version # of your unit and dealer mark up. You can call 1-800-samsung for nearest service center.
