SOURCE: my king kutter till will not hold gear oil.
If it is leaking around the shaft you can replace the seal.
SOURCE: just bought a 6 ft king kutter brush hog - no
I took a stab at this... I hope this is what you are looking for:
http://www.kingkutter.com/downloads/manRKRK.pdf
SOURCE: how much gear oil 72'' tiller
In Gearboxes use gear oil (type GL5-85W 140 or Triple Zero
Grease; which can be poured, and has "EP" i.e. "Extreme Pressure" additives.) Fill the gearbox to approximately half-full level.
SOURCE: Is the King Kutter ATV SeederSpreader suitable for
lime should be applied at 50 lbs per 100 sq ft which is heavy mark off 100sq and see what it takes at 3mph
