SOURCE: how to connect jawbone bluetooth device to htc evo
HOW TO CONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
SOURCE: Can HTC EVO 4G smart phone be used in India on
you can unlock your phone and use it to another network ,but you want cdma services available in specified model , you can use it for gsm after unlocking , if you want to unlock ,you can try codes here http://www.onlinegsmunlock.com/htc-smart/rs7wp9/
SOURCE: My htc evo 4g keeps freezing on me
download 3 apps. cache cleaner cleans temp mem, task killer shuts down unused open apps, memory booster keeps ur phone from stuttering, and apps to sd moves apps to your sd card to free memory.
SOURCE: htc incredible keeps saying droid
Try to update to the latest android version. Your carrier might help you with this because it is so new. However if you dropped it (etc.) and your carrier doesn't replace it for you, You can get the part at Droid Repair and there is a guide that shows you how to put in the part at Droid Repair Guide.
SOURCE: My HTC HD 7 phone
I finally had to have them replace the unit. If doing a factory reset does not help, then I would have them replace it. Mine started rebooting infrequently, but then started doing it more often. They didn't waist any time getting my replacement out.
Please make sure you back up all your contacts/email before proceeding. I use Google on my phone through the Outlook option. Google/Outlook syncs all my mail, contacts, and calendar.
RESET:
Software: SETTINGS > ABOUT > RESET YOUR PHONE
Hardware:
1) Turn off phone
2) While holding down both the Up/Down Volume buttons, turn unit on
3) Keep holding down the volume buttons until white screen appears
4) Press the Down Volume button to reset to factory defaults.
5) Restart phone
Id really like some help on this. It was working earlier. Ive already had to get a portable battery charger for this phone this exact week because the charging port came off the motherboard.
