ATR Sensor error or toner supply error. Abnormal detected patch reading value.
1. Check if the Drum Unit (Y) is installed.
2. Check the Drum Unit Relay PCB (Y) (UN26)
3. Check the Drum Unit Memory PCB (Y) (UN30)
4. Check the harness/connector between the DC Controller PCB (UN09/ J25) and the Drum Unit Relay PCB (Y) (UN26).
5. Replace the Drum Unit (Y).
6. Replace the DC Controller PCB (UN09)
Title : E001 Error Code That is Not Resetable Error : paper jam When the machine powers
up the E001 error code is displayed but cannot be reset. (Note: The reset
procedure for an E001 code is COPIER>FUNCTION>CLEAR>ERR) Workaround
: In this case, the Main Power Supply PCB Assembly was replaced. The machine
was powered up and the E001 code was able to be reset. The part number for the
Main Power Supply Assembly is FM2-0260-000. Remember, if the fixing unit
circuitry has an open or a short, the code may not reset. Be sure to confirm
the fixing unit wiring and try resetting the code before replacing the Main
Power Supply Assembly. Canon USA, Inc. Systems & Technical Support
Division1-800-528-2830
A.Removing thr drum unit.
Opem the front cover,shift down the developing assembly lockimg lever to unlock the developing assy.Slide out the left cover,holding the grips,pull out the drum unit.When removing the drum unit be sure to hold the two grips and take care not to scratch or soil it. B.Cleaning the photosensitive drum.
If the surface of OPC drum is soiled wipe it with a flannel cloth coated with toner.Do not use paper,lintfree or otherwise.
The drum cartridge is different from the toner cartridge. The drum has reached its life cycle and must be replaced. This is normal for any copier of that class.
The drum is not too expensive and not difficult to replace.
Were the heaters at fault. It is more like a thermister problem. Replace the thermisters, both. And I would also change the thermostat as well. When you are sure thatyou have removed the faulty unit reset by doing the following.. service mode/copier/function/clear/error followed byswitching the machine off and turn on again.
Muratec 2830
