Televison & Video Logo
Sam Stamport Posted on Aug 16, 2017
Sound not in sync with video
I live in a large metro area and use rabbit ears. Beginning a week or so ago the sound is no longer in sync with the video. This does a number on my brain especially on news programs. This problem occurs on KERA 13.1. It is not as pronounced on KERA 13.2 or other digital channels. I've complained to KERA, but get no response. Do I need a new antenna or has the TV just quit working?
  • Sam Stamport Jul 15, 2012
    I have checked the user manual for the TV and find no solution. The TV is an Emerson LC195EMX.
5 Related Answers
Anonymous
  • 137 Answers
  • Posted on Dec 07, 2007
SOURCE: Sony BRAVIA KDL46S2010 Sound and Pix not in sync - in HDTV channels only
This is a software issue with both the TV manufacture and the cable box provider. This will only be fixed when the cable company and TV manufacture sit down and work out their problem. Some cable company has taken the first step by updating cable boxes with different software.
Best regards
CircuitCity
Anonymous
  • 105 Answers
  • Posted on Jun 24, 2009
SOURCE: Digital channel 25 has no sound.
First make sure SAP or nothing similar is turned on.
After you triple check that just Contact ILO if it continues for more than 1month. This is a software error.
What state are you in?
What channel is this?NBC, ABC
Have you check this at different times of day?
What TV does your son have?
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jul 28, 2009
SOURCE: How do i manually add a digital channel to my tv? model: ILO-26HD
do u have the user manual for the TV? if you do the solution will be in there, if not (I suspect you don't) please give the make an model so I can try to look this up, but off the top of head there is no way to "assign channels" to a paticular remote setting.
Anonymous
  • Posted on Sep 09, 2009
SOURCE: TV freezes up when turned to channel 33-1
I had the same problem. I also use rabbit ear antenna , no cable or satellite. I was watching ch. 33.1 and the tv turned off by itself. The remote wouldn't work. The power on/off buttons on the side of the tv wouldn't work. I had to un-plug the power cord to turn the tv off. The tv forze on ch. 33.1 when I turned it back on.
I called Vizio, they told me they received hundreds of complaints from people in Texas complain g about these problems.
I was told to un-plug the antenna cable and re-plug it. I did this plus I re-scanned all channels. The problem has been solved, the channel (33.1) no longer freezes and the tv doesn't turn off by itself.
Hope this helps.
Anonymous
  • Posted on Feb 26, 2010
SOURCE: Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
Hook rabbit ears to a vizio tv
Weak signal? Try introducing a known working video source and see if set works. If so, try hooking up an antenna amp to the rabbit ears. If that gets some results you need to either get cable or a good outdoor aerial.
2helpful
Hello, I bought an ONN TV #LE-22G90 a few months ago and I can't receive any digital channels. My time zone is: Eastern time (I live near Sherbrooke, Quebec, Canada). The tuner mode is: Antenna. I...
I bought the same TV wich is in fact a Seiki TV, see the warranty paper. The television has digital and analog tuners so is able to receive digital channels.Our television receive signal thru a rabbit ear antenna and we had some trouble to scan all the digital channels. We had to change the orientation of the antenna to receive correctly the signals and we had to scan many times. We finally conected the TV to a roof antenna so we where able to scan all the channels of Montreal, north Vermont and north New York areas since we are living in the south shore in front of Montreal. After the scan was completed we conected back the TV to the rabbit ear antenna and the television is working correctly receiving all the stations of Montreal area with a very good picture quality.
Claude
Get no picture sound anything using rabbit ears
The FCC has changed to digital format for over the air broadcasts. You will need a digital converter box between your rabbit ears and tv now. Check radio shack or Best Buy.
1helpful
Toshiba Tv - Does it have a digital tuner?
That unit has a NTSC tuner. May be HD Ready but it does not have a digital tuner. Unless you live quiet close to a local Broadcaster, rabbit ears would be useless.
The only way you would be able to get HD is using a HD Set Top Box, HD Satellite System,
or HD Cable BOX, using the Componet or HDMI inputs.
Hope this helps
Skyassoc
1helpful
2answers
Im not getting any signal weak or strong! What am I doing wrong?
What's your source for signal? You need an antenna to be the capture source for your signal that has a wire going from the antenna to the INPUT of the box. That's usually coaxial input. The box is the middle component between your TV and antenna.
2answers
Possible to connect rabbit ears with prongs to Toshiba 27A43C ?
yes, it can be done, make a quick trip to radio shack to get the adapter you need.
please take the time to rate this solution.
Picture keeps rolling
do you have cable to the set or are you on rabbit ears if on ears adjust antenna for the strongest signal.
Toshiba CF36G50 Noisy when you turn it on
that sound is comming from the tube anode it is leaking you have to discharge the high voltage from the anode cap,then take off the cap clean the area with alcohol and put some red or clear silicone on the cap and anode connection replace back the cap on the tube leave to dry for about half hour,this will remedy your problem,no more static.good luck.
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
