Please help me to solve this solution of getting error 106 on google chrome
From what I have been able to figure out, error 106 is coming from your firewall. Reduce the protection of your firewall and see if that solves the error from happening.
I was able to fix it by disabling one of the wireless driver software (realtek) by going into control panel> network >adapters > right click and select properties and disable it.
There is a conflict if you have attempted to add few or previous versions of usb wireless adapters on the same computer and not removed the old one
SOURCE: uninstalled google chrome and now yahoo messenger icons dont work
I can solve your problem, just follo these steps:
Your problem is solved.
If you still unable to do it,I'll help you in detailed.
SOURCE: Unable to work with google chrome
kindly check if you have successfully installed the google crome in your computer/Laptop then you can try to reinstall it again.
SOURCE: google chrome i cant uninstall
hit control ault delete.... select task manager, click on the processes tab and look for any examples of google running. end them and then try to uninstall them.
SOURCE: i go to use google chrome but thires no internet
First check if you have updates for it.
Then go to options, hood tab, then change proxy settings button,
lan settings, see if the Use proxy server is checked, if it is uncheck it.
my google chorome is not conn.show error-106,101 etc.
