Water stays in the bottom of the unit. I can hold up the sensor and after about an hour it will finally be empty.
SOURCE: how do i remove the pump off my bosch
inside the dw remove all filters and in the sump there is a cover over the impellor with 1 self tapping screw remove and there could be a object stopping pump.
SOURCE: bosch dishwasher no water coming from arms but not blocked
Here is a tip that I wrote about that....
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
SOURCE: Water in Dishwasher Bottom
Hello Richard, Welcome to Fixya ! You've come to the right place. The problem you're experiencing unfortunately is a common one. The water inlet valve has been an issue with B/S/H built ( this includes bosch, thermador, seimens & gaggenau ) dishwasher's going back to the mid 90's. The part to repair it is available at most brick & mortar appliance part centers or you can check out on-line vendors such as repairclinic, apwagner etc. Do a search for part # 1105846 at repairclinic, you'll see what I'm talikng about. By the way it's about $35. Hope that helps move you forward. Let me know if I can assist you further, or need help on how to change it etc. It's relatively easy with Bosch. Thanks for coming to "fixya" for your inquiries and please take a second to rate this answer according to my helpfulness. Goof luck. Macmarkus :)
SOURCE: Bosch 6802UC dishwasher is leaking water from bottom of door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
SOURCE: Our Bosch dishwasher has water
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
w;rlt,ghsdf;glh,dsf;gdl;fh,sf;
I have actually fixed my dishwasher. I checked the filter, it was clean. Checked the hose and it was full of water but was not clogged. I ordered a drain pump from Repair Clinic.com and it fixed the problem. The old pump had failed over several weeks, so it was difficult to troubleshoot. Works like new.
