It's either not establishing a connection with the Wii, or it's batteries need changing. I personally have never had to connect a balance board with the Wii for the first time, I only played with it at my friend's house.
Wii red light going batty flashing like every 1/3rd of a second, and it will not turn on. I FIXED MINE BY UNPLUGGING EVERYTHNIG CARDS, CABLES, FROM EVERYWHERE, AND REMOVE SDCARDS ALSO, AND DISCS, BOTH GC & WII CARDS, SENSOR BAR PLUG, POWER Plug *ALL THAT'S PLUGGED OR INSERTED... Now i plugged everything back in ACCEPT Not Sensor PLUG To back of wii, then the light quit (This is after 4 min break all undone...) And then plugged the Sensor plug and THEN as i finally plugged in the POWER Plug I first held the SYNC red button on the Wii, and then plugged it in and WAH-LAH Isue Resolved Immediately, KUDOS for the hints Cheerz & Peace Love Banish Fear/ hate to not even give it thought in root thoughtfulness.!. www.fb.com/stanleydeanparker/
I AM NOT GOING TO AWNSER YOU Q BUT I CAN TELL YOU THAT THAT IS THE SAME THING THAT IS HAPPING TO OUR SO IF YOU GET THE SOLUTION BY ANY CHANCE WILL YOU LET ME KNOW
open your wii controller battery compartment and your wii memory card compartment theere will be red buttons press them then try again this has happend to me before and it worked.
Have you replaced the batteries and you also need to press the SYNC button inside the battery cover underneath the wii board and the SYNC button on the Wii console at the same time.
Wii Console Won't Turn On, and Has No Power Light
Situation:
The Wii console won't power on, and the Power LED is unlit
The console powers on, but shuts off after a few seconds/minutes
Attaching an accessory to the console turns the power off
Information:
This issue can be caused by an accessory or power surge tripping the circuit breaker on the AC Adapter.
What To Do:
Check any accessories attached directly to the console to make sure that it is licensed and undamaged. Unlicensed or damaged accessories shouldn't be used with the console.
Try using a different wall outlet, or plug a different device into the outlet to make sure the outlet is providing power.
you need to open up the back (After game is started) then press the red sync button on the board then quickly press the red button on the front of the wii. Same happenened to me and it worked fine.
