Question about HP Officejet 6310 All-In-One InkJet Printer
My HP Officejet 6310 All-in-One will not scan
When I try to scan a document under the Adobe I receive the message "No connection. There is no computer connection. Refer to device documentation to trouble shoot. Press OK."
When I push OK, I receive this message "No Scan Options. Refer to device documentation to troubleshoot. Press OK"
I press OK and it clears all messages, showing only the date and time.
I shut everything down (computer and All-in-One machine) checked all of the cords, turned everything back on and I still receive the same message.
I can not figure out where to locate the device documentation to try and troubleshoot the problem.
Is there any advise that you could offer me to resolve this problem?
I greatly appreciate any guidence that you can offer me.
  • 7 more comments
  • larrystarr45 Dec 25, 2008
    i have the same problem except my printer works for scanning photos fine, i have a mac and the photos go to iphoto with not problem, but when i scan to documents it looks like it goes through but can't find it in any probram
  • Anonymous Jan 04, 2009
    I purchased a HP 6310 All in One Printer and it will not scan. I get the message No printer options
  • benzepeda Jan 08, 2009
    I just right now have the same problem as dbell232's scan problem. any solutions yet?
  • Anonymous Mar 24, 2009
    this printer is getting my nerves!!!!!
  • lincolnoct Apr 14, 2009
    i have the same problem as above. any solutions pls email me at lincolnoct@yahoo.com.sg
  • keithkhelfri Apr 16, 2009
    I have the same problem - get the same messages - please notify me of a solution
  • Anonymous Apr 18, 2009
    printer will not scan
  • shellyray2 Apr 22, 2009
    I have the same problem as dbell252
  • HPhelpneeded Apr 27, 2009
    same problem how do you fix it?
Use thunmdrive then can scan
Posted on Apr 17, 2009
    Problem Solver:
  • 5 Answers
I am not able to fax from PC to 6310 but did find an update on HP 6310 driver page the corrected the scan issue.
Posted on Dec 11, 2008
I am having the same problem as dbell232 , how can I fix this problem.
Posted on Apr 16, 2009
SOURCE:
HP Officejet 6310 xi all-In-One - What should I do to scan from computer Windows7 Trying to scan from wireless computer, what steps do I need
if you have installed the full feature software of the printer on your computer then you would find HP solution center on the desktop screen. double click on it and then Solution center opens up.. then click on scan document and follow the on screen process it will scan..
Mar 26, 2011 | HP OfficeJet 6310 All-in-One Printer...
My printer is evidently installed correctly, since I am able to print OK, but I cannot scan, I get an error message when I press start scan and OK - "no scan option", and refer to "device documentation"
on your computer go to hp solution center..
under that go to settings..
then scan button settings..
over there add all options to the right side..
then try..
Oct 22, 2009 | HP Officejet 6310 All-In-One InkJet...
Won't scan through network
You need to make sure that does it print or not. If it is printer then you need to disconnected printer HP 6310 printer and uninstall hp software using printer installation disk after that reboot your computer and reinstall completed printer software.
Thnx
Sachidanand
Aug 16, 2009 | HP Officejet 6310 All-In-One InkJet...
I try to scan a picture and I get meesage refer
Just try pressing copy see what happens.
Make sure you havbe a direct connection no network involved
At which place are you reading this message at the computer or at the printer
Since you are not clear I have to ask these boggus questions
Jul 31, 2009 | HP Officejet 6310 All-In-One InkJet...
"NO SCAN OPTIONS" in HP Officejet 6310 all-in-one
You need to install the software and driver for the version of windows that is on the new computer.
Link to you model printer/scanner below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1119598〈=en&
Mar 19, 2009 | HP OfficeJet 6310 All-in-One Printer...
IOCR application has encountered a problem and needs to close.
hi,
i think u get that error message when u scan a document and store in pdf format, there is several reason for that, u can try any one of the following steps,
1) in add an remove program, remove or uninstall  a software called OCR by read iris.
2) down grade ur adobe reader to version 7 r below, it should resolve the issue.........
Regards,  raj_p5983
Jan 21, 2009 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-in-one Scanning issues
I believe u have Vista. There is a known issue with Vista. The drivers in the Windows Vista operating system do not support button press functionality on the product. There is a workaround documented on the HP site. I had the same problem and this KB article helped me resolve it.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809848&lc=en&dlc=en&cc=us&lang=en&product=1120043
Dec 10, 2008 | HP Officejet 6310 All-In-One InkJet...
Faxing a word document
hi, i would like to know if you have an HP officejet 6300 fax icon???if you have try to print the document using the fax icon DO NOT used the normal HP officejet series icon.if you did used the fax icon it will display the FAX dialog box,input the necessary information needed.just follow the window..
i believe you can now send the fax..
send me feedback for further troubleshooting....
Aug 04, 2008 | HP Officejet 6310 All-In-One InkJet...
Won't scan document to my mac os x
download the new drivers and firmware from the HP site. that is updated and should work just fine
Apr 30, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Officejet 6310 All-In-One InkJet Printer Logo
2,781 people viewed this question
Clive
Clive
Thomas F. Schneider
