NO computer stated, make COmpaq,. no model vast sold all old.
NO OS stated.
wow, must we guess the moon ,stars and sky?
HP owns Compaq, and compaq is mostly a dead product now and for support (free) why mess with relic iron and OS>?
the newer PC's have hot key, F10 or F11 (changed at VISTA)
its job is reload the OS, called HP restore.
if those keys fail the hdd is not good..
HDD not Original
not HP, hdd, with HDD restore partition on board.
or HDD is bad.or someone corrupted these partitions.
or someone loaded, MS OS on it. do not load Microsoft disks her.
or was never there new, as was true on first compaq.(unstated by u)
if the hdd is bad it its bad, the bios test is just toy, we have vastly better tests disk, endless topic, can take all day to test any HDD.
the HP disk sets are not sold by HP but are 3rd party
you can read just like me, look your disk by self
https://restore.solutions/dv/laptop/compaq/
if the HDD is good, (may be not)
there are only 2 pathes.
HP install disks
or hope F10 works, I cant read you book to you ,and would but you never once disclosed the service tag data.
see this crude example that is a service tag.
it tells the helper what you own..
HP will ask for serial #, as that also tells options I cant ever guess.
SOURCE: My PS3's hard disk file system is corrupted
This happened to my husbands PS3 also. He put it into another PS3 and reformatted it and then when he got home and put it back into his it asked him to reformat again and this did the trick. It's been working ever since. He called Sony and they wanted him to send back his hard drive and they would either fix or send him a "new" refurbished one for $150. I don't think so!!
SOURCE: Dell GX270 Maxtor 7Y250M0
If you are getting bad block reports on your hard drive, it means that your hard drive media has suffered some degradation. It could very well be that some system files are being affected by this, thus continually triggering the problem. You may not like the suggestion I have, but it looks to me like the most solid solution (saving you hours and hours of troubleshooting).
Backup all files from your hard drive, save all of your browser shortcuts to backup files, then perform another Windows XP installation with a low level format of the hard drive. I know a PC specialist with many years of experience that says hard drives develop faulty areas over time and that every 5 years or so, it's just best to back up data from the hard drive and perform a low level format. This resets the device completely. If there are any faulty areas on the disk, they are skipped over--to the operating system, the drive will be perfectly fine.
This is not a guaranteed solution, but it sounds to me like it will eliminate a lot of possible culprits for you. Good luck.
There is an alternate way to restore your HDD. Turn off your system and when u see the red light, hold the power button in front until you hear a total of 4 beeps (1 alone, 1 alone, 2 together). It usually works on second try. it should show a screen and say hook up controller with a usb cord. Then it should show i think 6 options. Choose the restore option. it should work.
Hope it works and wish you all the best!
P.S.- I just got the 80010514 error on my ps3 and my ps3 games dont work anymore :(
SOURCE: short self test failed
Your best option here is to take the drive to a data recovery specialist.
If you google data recovery it will come up with some sites where you can find local offices to do this
SOURCE: Error 0x400 100 130000 1002 while restoring factory image HP
I am assuming you are trying to reinstall Vista. Apparently, HP's recovery partition is less than perfect and the recovery disc you created is probably worthless. (and you can NOT make another one, they only let you make one!) You are not the only person to have this issue.
Here are some things you can try:
1) Borrow an OEM version of Vista from someone...anyone. It sounds like you are proficient with PC's and maybe you know someone who works in IT. Use your product key (25 digit key code) and you should be able to reinstall.
2) if you like Vista, buy yourself an OEM version. It will not have all the factory (HP, Dell, Acer, whatever) BS on it. It will positively work because your hardware if fine.
3) Put XP on it. Personally, I think Vista is a mess. Microsoft is working on "OS7" and soon Vista will be like "Millennium".
Sorry it's not an easy fix, but glad your hard drive and memory show no errors.
