After turning on the laptop it goes fuzzy when the Asus logo shows up. After that it's all dark. But the HD and Cooling fan is running! what can I do now????
SOURCE: Asus Eee Pc 900A Linux
restart computer
a screen comes up and says tab and f2 at the bottom but at that screen press f9 repetidly untill a black screen comes up with 3 choices
click 3rd choice
it tells you wat to do the rest of the way
go to my website valenzuela.synthasite.com
and email me [email protected]
SOURCE: black screen
hi,
do you see any error or does it go blank after you see the windows logo,
if it goes blank after you see the windows logo, that means that there has been software misconfiguration at the level of windows operating system, restart your system using the power button and wehn you see the asus logo at start start tapping F8 key, it will lead you to a menu that will say boot into safe mode, select safe mode and enter, see if you are able to boot into safe mode, if you are then what we can do is restore your system back to a previous date
to do that in safe mode follow the following instructions
Caution: After a system restore the configurations/software that are done after the restore point will be lost
for system restore
click on start button > go to run > in there type in without quotes
"%systemroot%\system32\restore\rstrui.exe"
system restore window will open
further Queries are welcome
Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
If you find my solution helpfull please do rate me
SOURCE: I have a Compaq Presario C300 laptop. When I turn
It is a OS problem. your notebook is not booting in OS. so i advised ot you pls reinstalled the OS.
SOURCE: Hi, I have a problem with my ASUS Z84F laptop. I
Hello.
Your problem certainly could be a motherboard issue, but try some other steps, first.
Connect an external monitor to see if your display is a problem.
Your fan could be full of dust or faulty. Disconnect all cables and remove the bottom cover. With a can of compressed air, blow the dust from the fan. Leave the cover off and reconnect the power cable. Power on and see if the fan moves. If it does not move, the fan could be replaced by removing some screws and disconnecting a cable or two. Not difficult, but only do if you are comfortable.
Other suggestions are heatsink paste. But, a professional should do that for you.
Hope this helps.
SOURCE: My mini laptop turns on and shows Asus screen and
remove the hdd and power on.
after that you can see some different massege like as no hdd installed, no operating system, or
trying to boot via nic, etch.
if can see you nrrd to repleace the hdd.
