Konica Minolta Bizhub C552 Copier Logo
Server Disk Full error
When trying to scan large documents (over 10 pages) to an email address we are getting "server disk full" error and there is no error code. I have tried searching KM documentation for this but cannot find any reference. The only thing I have found suggested a firmware update but do not find any for this model. Any help would be appreciated.
4 Related Answers
Anonymous
  • 167 Answers
  • Posted on Jul 02, 2008
SOURCE: transfer error with large documents
If it was a memory error the copier would indicated this.
It may be due to bad line connection or limitations of the server, but if you are getting a log error, it is most likely a bad connection to the internet.
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Oct 20, 2008
SOURCE: Scanning to C352 server connect error
Check you smtp server settings in admin settings. Verify there correct. If your smtp server needs your email address and password to send, that should be populated as well under them smtp authentication settings.
firecontrol7
Norman Weimar
  • 7035 Answers
  • Posted on Mar 25, 2010
SOURCE: server connection error when scanning
have you set up your scan Email account with you page Scope disk with the copier. is the server set up for scan to email. Also check the konicaminolta web site for scan operator manual. Down load the scan programs
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
blazebusines
San Diego Copier Repair
  • 128 Answers
  • Posted on Jul 31, 2012
SOURCE: How to change scan to email default email?
Download the free user manuals directly from Konica Minolta support and you will find details on all the settings you can adjust for your copier.
There are 26 manuals for your machine. I would just download the network scanner user guide and the Copy/Fax/Scan/Box Operations Quick Guide and look for the procedure there.
http://kmbs.konicaminolta.us/wps/portal/web/home/support/manuals
Incorrect number of bytes written to disk
A search of the Oracle Metalink site ( http://metalink.oracle.com/ ) for the ORA-27063 and ORA-19502 errors returns Oracle Document ID 271511.1. This note indicates the hard drive of the Oracle server is full.
Resolution:
Free up disk space on the Oracle server. Refer questions regarding the correct way to clear files from the Oracle server to Oracle support.
http://www.symantec.com/business/support/index?page=content&id=TECH38253
Server disk full in bizhub 420
malfunction was detected cs remote care c2403
1helpful
Can't open Excel files after installing OS X 10.8 Mountain Lion on my Mac. HELP PLEASE!
Try repairing disk permissions by running the Disk Utility application until you get no errors (then restarting).
Hope by doing that you get the solution.
When i scan to email, i get an error; "send error 2202" and the document is not sent to email. The Kyocera fs-1028mfp printer is connected to the LAN using a network cable.
Apparently there is a communication error between the printer mail server. Can you ping both reliably ? Is it an internal mail server ? If yes, can you ping the printer from it ? Did you try changing the network cable ? How about IP addresses ? Could there be a conflict ?
Cheers,
Franck Horlaville TAM Software
2helpful
I own a samsung GT I 9000. Have been trying to synchronize with my corporate mail server without success in spite of following the screen tips. Could you please help me or atleast guide me to a custormer...
Check the security settings of your mail server to ensure you're not being blocked.
Here are some 'standard' settings that may work with your system.
Gmail Incoming Outgoing
Access Type Web & POP3 Web & POP3
Email Address Format [email protected] [email protected]
Account Username Format
Full email address Full email address
Server Address pop.gmail.com
Use SSL: yes Port:995 smtp.gmail.com
Use SSL: yes Port:465
Hotmail Incoming Outgoing
Server Address pop3.live.com smtp.live.com
ic24 Incoming Outgoing
Server Address mail.totalise.co.uk smtp.tiscali.co.uk
UKGateway Incoming Outgoing
Server Address pop.ukgateway.net smtp.ukgateway.net
UK Online Incoming Outgoing
Server Address pop3.ukonline.co.uk smtp.ukonline.co.uk
Vippowerent Incoming Outgoing
Server Address pop.vppn.com
Virgin.net Incoming Outgoing
Username Username
Server Address mail.virgin.net mail.virgin.net
Wanadoo Incoming Outgoing
Email Address Format username@ name.wanadoo.co.uk username@ name.wanadoo.co.uk
name.wanadoo.co.uk name.wanadoo.co.uk
Server Address pop.wanadoo.co.uk smtp.wanadooasdl.co.uk
World Online Incoming Outgoing
Email Address Format username@ worldonline.co.uk username@ worldonline.co.uk
Server Address pop.
tiscali.co.uk smtp.
tiscali.co.uk
Yahoo.co.uk Incoming Outgoing
Username Username
Server Address pop.mail.yahoo.co.uk smtp.mail.yahoo.co.uk
Yahoo.com Incoming Outgoing
Username Username
Server Address pop.mail.yahoo.com smtp.mail.yahoo.com
Settings - E-mail
You'll need to complete all steps for this to work. Make sure that if you have to enter O2 in the settings you use the letter O and not a zero.
The following settings are if you use O2 Email as your ISP (Internet Service Provider).
If you require different settings eg Yahoo, Gmail etc please click here
1. Tap the Application tab on the bottom of the screen
2. Tap Email
3. Tap Next on the Welcome to Email setup screen
4. Tap on the Email address text box and enter your Email address then tap Done
5. Tap on the Password text box and enter your Password for your Email account then tap Done
6. Tap Next
7. Your phone will now try and download your setting to your phone and set up your account, if this can not be done you will see the message, Setup could not finish. Unable to open connection to server. Tap Edit details to continue.
8. Tap Manual setup
9. Tap the Username text box and enter your full Email address then tap Done
10. Tap POP3 account
11. Highlight POP3 server and tap the text box and enter mail.o2.co.uk
12. Check that Port is default set at 110
13. Highlight Next and tap
14. The phone will now check your settings
15. Tap the SMTP server text box and enter smtp.o2.co.uk
16. Highlight Next and tap
17. The phone will now check your settings
18. Tap Next on the Account options screen
19. You now have the options to add a name for your new account plus add your name to outgoing messages
20. Tap Done
2answers
Konica Minolta bizhub reads "server disk full": how to unfill server disk? or how to fix?
CAUSE: Machine memory is corrupt and the max out time needs to be increased.
SOLUTION: Perform a Data Clear:
1. Enter the Tech Rep mode.
2. Press System 1.
3. Press Initialization.
4. Press Data Clear.
Also browse to the NIC, enter Admin mode and set the connection timeout for E-mail to 300 seconds.
Server connection error when scanning
CF2002 Trouble Scanning to Email
scan to email can only be setup to work on a internal email server if the email server is external it will not work. also make sure you input the admin email address and the from email address when configuing the machine
3helpful
Error Log Cannot store data of this size. Document Server
The document server portion of the copier not only has limitations to it but it has compatiblity problems with it as well when dealing with mulitiple pages. The SODIMM card could be set for 64mb on your copier and the buffer is too small to work with it. It doesn't work the same way as a fiery server does on todays copiers.
Ricoh tech support has told me there are three ways to use the scanner:
1) Scan to e-mail.
2) Scan to ftp server.
3) Scan to document server using a seperate PC as the server.
4) Scan to a local computer using Desktop Binder.
www.ricoh-usa.com has software to do 3 and 4. #1 can be setup by adding the smtp server to your copier in the file interface section by pressing the user tools/counter. You have to have the IP address to the smtp server in order to get it to work. You can contact your internet provider to get that.
Using the document on the copier is for temporary storage and isn't designed to handle big jobs to it as well. You can experience storage problems as well if your print server is full or you are storing faxes to the memory.
The memory can be updated to the copier as well. It can read a SO DIMM PC100 card up to 256 MB. It's an older memory module that they use on older notebook computers. You can get them at computer stores or get them through PNY.com.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
