Mongoose full-suspension mountain bikes, like the Ledge 3.1, have a little bit of height adjustment for the handle bars. See the manual at https://www.mongoose.com/pages/product-manuals . The current link to the appropriate manual is https://p.widencdn.net/brqquy/OMMGFS-1_Mongoose_FullSuspension_OM . Start at page 18 (20 of the manual in the browser) and determine the type of stem on your version of the bike. The quill stem version has minimum insertion marks that must be below the top of the headset and not visible. For the threadless stem version of the mountain bike, you adjust where the handlebars clamp onto the steerer tube. However, this is very imited since there should be only 1/8" to 3/16" gap between the top of the handlebar stem and the steerer (stem) tube. The is where the top cap and bolt to replaced on the handlebar stem and thread into the steerer tube.
This will depend on what sort of stem you have. Most mountain bikes these days use a clamping style stem that simply grips the steerer tube on the fork. Some will have limited adjustment in that they may have a stack of 2 or 3 spacers that you can place either over the stem or below the stem. This does not give much adjustment. On my wife's bike the stem is actually adjustable similair to this: MEC 110mm Adjustable Stem Mountain Equipment Co op
and might be a good option for this bike.
you can't tell without looking to see what is on the bike but if it is a thread-less stem you can try taking handlebar off an then take stem off head tube and turn it a 180 degrees, the two are connecting the opposite things. that should raise the angle of the stem and bring handlebar up. that is a free solution.
unfortunately, your bike uses a threadless stem. meaning you cannot raise it, you must replace it with an adjustable one, or get a stem with a steeper angle.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
You will need a 6mm allen key to loosen ( turn anti clock wise) the handlebar stem bolt which when you sit on the bike and look down its just under yer nose :)
Please make sure when you raise the handlebars that as it lifts up there is a marking on the side of the handle bar "stem" with markings like this """"" if you see these you need to lower it down so you cannot see these.
