I have a Samsung GT-C5510 and recently, whenever I have gotten any incoming calls, I can answer the call but cannot hear the voice of the person who rang me, however the person on the other line can hear my voice. How can I fix this?
Maysie, This is a Speaker problem (hardware problem), show some official repairer to change or fix it, but temporary you can use headphone or Bluetooth to communicate by your device. Best of Luck.
Testimonial: "Hi Priyesh, thanks for this helpful answer and clarifying what the actual problem was. I will try using a headphone and see where that gets me. Thanks again"
SOURCE: samsung sgh-a707 cellphone, blocked calls
go to settings, then call settings, then all calls and you should be able to help yourself from there
SOURCE: All Incoming Calls Show As Private Number
First thing : the person who's calling you have CLIR . Don't put the same number to phone & SIM. Use the phone memory and also save numbers in international format.
SOURCE: NOKIA 1600 I CAN HEAR THE VOICE WHILE THE OTHER
Your MICROPHONE is not working.Please get it replaced
SOURCE: Phone: Samsung Propel Problem: I
Mine also did this. It only does this when you do not have signal. If you do have signal and it still does this you just need to call ATT and confirm it with them. They ended up sending me a new one that has better software on it for free.
Hi Priyesh, thanks for this helpful answer and clarifying what the actual problem was. I will try using a headphone and see where that gets me. Thanks again.
