Yamaha HTR-5850 Receiver Logo
Posted on Jul 12, 2012
Make microphone work - Yamaha HTR-5850 Receiver
Web cam works but microphone does not work
Hi There, check your microphone settings. Click volume control in the taskbar, and check microphone level. If that doesn't work, try looking in control panel with the microphone settings.
Desktop Microphone 600 works on roommate's HP but not on my Dell
Be sure your microphone is working fine, try to reconfigure your sound device. maybe you've miss something
1helpful
My internel microphone doesn't work with Skype -
You need to check the Microphone setting in Skype.
Open Skype, Click on Tools - Audio Settings, then in Microphone settings click the down arrow and select the built-in microphone then save the settings.
If the microphone you selected doesn't work then select a different one.
1helpful
Cannot get laptop microphone working
Double click on the little speaker icon on the Desktop toolbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure he microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder or whatever application you are using and try to record. If this does not work I would get an external microphone plug it into your laptop and try recording again. If the external mic works then I would think that you internal microphone is not working. There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
2answers
Microphone is not working
i have compaq Presario c700 laptop
but my external microphone is not working & also inbuilt microphone is not working.
1helpful
4answers
USB Microphone for Nintendo Wii
yws it will any microphone designed for the wii will, i have a few singing games and tis microphone and they all work with it.
hope this helps
2helpful
Microphone Won't Work
check your cpu port for microphone to motherbord.
or may be microphone may be faulty.
3answers
Did your Microphone come with a Software CD?
Microphone
my mic was never working i bought it today and pluged it in to my computer an it's not works when i talk in to it and yes it is on
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
