Please, I need the code to program the direct tv remove to turn on and off my ILO 32 hd tv. They gave me two different codes and none work with this tv. Please, if you have any codes or some kind of a procedure, I would like to know. I hate using two remotes. Thanks. Al
In used 10463 for my Direct tv remote...it is an Emerson code. It worked on my 27inch Ilo, from Walmart. Good luck.
DirecTV now supports ILO. Here are the codes:
11286, 11603, 11684, 11990.
11684 worked for me (42" ILO). The catch is you need a new remote! My one year old remote would not accept these codes.
I have an Ilo CR3201L8A Tv and RC64 Direct TV remote, code 10171 works just fine for me.
For Directv remotes try Toshiba codes. I used Toshiba code 10156 on my model RC23 Directv remote and it worked with my 32" ilo!
1. Switch the selector to TV on the top of the remote.
2. Press both the Mute & Select buttons at the same time until the green light blinks twice.
3. Enter code.
4. Press Power button.
Make sure you are in front of your television about 3 feet away. The remote signal doesn't seem to work well even at a slight angle.
P.S. If that codes doesn't work here are the other Toshiba codes listed on Directv.com for the RC23 Remote.
11656 11256 11704 11356 10650
10060 10154
Follow these instructions from the Direc TV web site. or go to http://www.directv.com/DTVAPP/customer/downloadPage.jsp?assetId=1100066 and select remote controls and select your model of remote for instructions. If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes. 1. Turn on the TV or component. Insert a tape or disk if applicable. 2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired. 3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys. 4. Enter 9-9-1 followed by one of the following fourdigits: 10 5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use. 6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off. NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component. 7. Use the CHAN- key to step back a code. 8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key. NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Ok... I HAD the same problem... Direct TV Remote wouldn't work with Olevia TV despite ANY codes that Direct TV or anybody replying to solution forums say they are. I DID find a solution though! Use the Remote's Code search function, BUT SKIP the first code that turns off the TV... CONTINUE to press the Channel + button after manually turning the TV back on after the first successful code that turns off the TV. This is the ONLY solution that I have found that works and I haven't seen it posted on any solution site. TRY IT.. BET IT WORKS FOR YOU AS WELL! (If not, skip the 2nd code as well... Olevia HAD to have copied a major brand-name's remote code scheme because all the generic TV manufacturers end up copying a known companies' setup... but a LOT of them neglect to tell you which brand they copied... I have owned many generic TV's that I couldn't get codes for for many remotes through the past 35 years... and this has been the case on ALL OF THEM!) Keep this in mind when you think you can't get a remote to control basic functionality with ANY TV and ANY remote.
The remote code is11684
I found that my Direct TV DVR lists Olevia codes as 11144, 11240,11331, 11610. However, my DVR isn't attached the Olevia. I have a newer box with the RC64 remote on the Olevia and even without the TV being listed in the brands, I used 11610 code and it works just like every other TV I've programmed with Direct TV.
Guys a remark like "buy samsung" is not a fix, it is a waste of time. Please if you have an answer, give it. If you don't have an ACTUAL answer than please don't post. Me having to post this for the idiots of the world is a waste of my time. I don't like wasting my time. I bought an Olevia for my Grandmother. Great deal and actually the picture is better than my 42" Panasonic that I paid $1,000 more for. Olevia is a OEM product. They are actually the same as Samsung and LG. Same parts. And Yamaha, that is why the Yamaha code works for some and 11610 works for others. OEM products are the same as name brand.
Just out of curiosity, how many of you Olevia product purchasers got your LCD Flats as a promotional attachment. We got ours with a manufactured home through a Fleetwood Vendor. Could there be something to this tech. problem? Like Fleet... got a package discount and pulled a Windows/Gates/monoploly thing? I'm pissed if the Direct TV/Olevia HDTV(242T in my case)remote incompatiblity isn't a coincidence! And they dumped these TVs off cheap to Fleetwood and passed the problem off to us...anyone want to pursue this? JH Idaho
Call the company
I could never program my Direct TV remote to power My OLEVIA TV or control the volume on my RC32, but switched to a Direct TV RC65R Remote and was able to use the code 11610 and Power TV and control Volume. YAY!!!!
Hope this helps someone else as well!!
The remote 3 sylvania codes for volume control dont work.
I have a 3 series Olevia and found that the code is 11610 for my TV.
Code in the rc64 is 11610 for olevia
You need to reset the remote it is in the menu under setting how to reset the remote. Then try reprogramming their numbers in.
I worked on an Olevia just yesterday (2-12-08) and found that the remote was not programmable to DirecTV. During the installation I asked the owner what he paid for the set, he replied that he "got a great deal" by paying only 500 dollars. Some great deal!! My suggestion....go with a name brand, pay the extra money.
Buy a Samsung, better picture and works with Directv remote
I also had same problem and I tried these codes:
11603 worked for my ILO 32 HD TV.
Thanks
Vin
Thanks tvtek ur link to DTV supllied the codes needed
BTW Syntax (Olevia) highly regarded tv's. My 65" has
the Realta HQV proccessor . :) :)
direct tv remote does not work with olevia tv
My ilo 32 LCVD TV came without the remote in the box. No problem. I'll have the cable remote programmed to run the TV. Wrong. The TV cable company has no code to program their remote to an ilo TV. So I bought a sony universal remote. They listed ilo and gave a remote code number of 098. It didn't work. So I went through the manual steps over 200 mtimes. Still doesn't work. I called Sony. They gavwe me the 098 code. I told them it didn't work. They had no other code and said the chip in the remote must not be compatible with an ilo TV. What now. I can't change the channel manually to channel 3 so the cable box will work. The TV is worthless.
i dont know if they have a code , damn walmart
54523454235
I have a REALLY BIG universal remote and I need the codes for my television it's a Viore flat screen.
I need the codes 2 a ilo 32 inch tv i also have the remote it come with
cannot program direct tv remote to work with tv. no code from direct tv
direct tv gives these two codes for this remote 10765, 10767 . hope this helps
Try using the 'Durabrand' codes with your Direct TV remote.. I used 10463 with mine and it worked. I am now able to turn the TV off & on and adjust volume..I have a 27" ILO television
Is it possible Olivea is selling their 32" without a renote code that will work on Direct TV. Called and tried everything. Anyone solve this problem?
cant get remote to work on direct tv..they say they have no code
direct tv remove cannot be programed to turn on or off or change volume
I connot find a remote control code for my tv. I have a ilo tv and I have direct tv and my remote wont work it. Please help.
volume control doesn't work
have 2 Olevias 237T and 232T and have same problem. Contacted bot Olevia and Direct and tried the generic code for Direct TV plus the (four) 5 digit codes Olevia has posted on their website....none work! By the way it is the #1 FAQ and gives the 4 codes that supposedly will work for Direct TV- Not.
37 lcd wall screen oeliva tv need code to program direct tv remote.
I have direct tv and need the code to program my remote to turn the tv off and work the volumn
I have an ilo model lct32ha36. I have a Cablevision remote and cannot program my remote to do anything on the TV. Have heard this is common. Can anyone find the codes. The code given in the Cablevision book does not work.
my ilo tv remote wont do aanything i can only turn the tv on and off
ilo remote control only turn tv off/on/does not control any other function
cannot use the direct tv remote to control the volume,on/off etc.
JAN. 2018..MY MODEL IS ILO - LCT32HA36 I USED CODE 1684 TO PROGRAM MY REMOTE FOR DISH TV. WORKS PERFECTLY. TOOK ME OVER 1 HOUR TO FALL UPON THE CODE!!!
