SOURCE: reset WorkCentre 24, Xerox
In menus you browse to the service tab, then serivice diagnostics. Go to NVRAM reset and perform the NVM reset.
Before you do that, print out a configuration page if you want to rememebr the network settings. It will set the IP address back to default also.
SOURCE: xerox workcentre xd100 copier NO POWER
hi,check power cord if the power cord correctly connected the problem is power supply.
SOURCE: Service Manual for Xerox WorkCentre m55. URGENT!
Does this link help?
http://www.support.xerox.com/go/results.asp?Xtype=docs&prodID=WC_M55&Xlang=en_US&Xcntry=USA
SOURCE: u4 in workcentre 5020
it is problem your printer cartridge chip is demage change it and buy a new one origin
SOURCE: need to reset replace drum message on Xerox
You can replace the chip on the drum unit. Or the drum unir itself.
Google a business called " the parts drop". They will have both the chip and or the drum cartridge. It is not resettable with a diagnostic code.
how to set machine motore
