The remote unlock for EOS car door with the key is not working. Remote locking is fine. Remote boot opening with the key also fine. Just the remote unlock for the door is not working. When I unlock the car using the key the alarm is activated.
For better result download the pdf file
2007 Volkswagen New Beetle Workshop Repair Service Manual PDF Download
SOURCE: 1998 Jetta Passenger Door Won't Unlock
I had a similar problem with my son's 1998 Jetta K2 4 door. I sprayed loads of WD40 into the locking area from the end of the door through the clip slot, worked the mechanism sprayed some more and finally it start working. My mechanic said these are very prone to moisture causing rusting on the moving parts.
SOURCE: VW 2000 New Beetle door sensor/car alarm goes off when doors open.
I found a thread - http://forums.vwvortex.com/zerothread?id=1542461 that details the repair of the soldering on the key lock door module. Our 2000 new beetle had the same issue. Also sometimes it refused to start. Soldering pins fixed it all.
Also see http://forums.vwvortex.com/zerothread?id=1015107 for releasing window from track, And door handle from inner panel.
I ripped the door apart and re-solderd the pins. I only had one pin with cracked solder but two others looked thin so I did them while I was in there. It's about a four or five hour project if you have all the tools. (8mm triple square also called an 8mm internal was the hardest to find - Also needed Torx T8 T10 T15 and T30 plus Philips Screw Driver. )
Project is difficult but not too bad for the mechanically inclined. A 7 on a scale of 10.
Since re-soldering pins - no more issues! My guess is that a VW dealer would get $200 for a new moduel plus 5 hours of service time for this gig - easily a $500 to $1000 bill. My cost - several new tools - about $25.00.
SOURCE: Mk4 Golf. Remote locking, windows and interior lights not working
Maybe fuse number 6 is blown (check lefthand side of steerning wheel where all teh fuses are located - you must open the door)
SOURCE: mk 4 golf, remote key not locking/unlokcikg doors?
unlock with key and hold key over for 30 secs(windows may go down)then lock with key and hold over for 30 secs(windows may go up)then press remote unlock button and hold for 30 secs,you have just reset system...the closer you have to get to the car for the remote to work the lower the battery power.sensor on top of dash(little black dimple)rarely,if at all, goes wrong.....
SOURCE: 2002 VW Cabrio alarm problem:
i have a 2002 vw cabrio and won't start after i took out the battery everbody is telling me that anti-theft is lock mode how do i rest it so i can start my car
