Crown CTS600 2-Channel Amplifier Logo
Tony Cardoza Posted on Jul 12, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Crown CTS 600 manual
Where can I download a service manual
Electro Med Services
Level 3:
  • Crown Master 6,694 Answers
  • Posted on Jul 14, 2012
Crown Master
Level 3:
Answers
6694
Questions
Helped
1871820
Points
21433
Here i have added the link to the Operation manual of Crown CTS 600 .
Crown CTS600 Manual
Ajin
1 Related Answer
Anonymous
  • 121 Answers
  • Posted on May 01, 2009
SOURCE: blinking red fault warning
timy check the speaker conections before condeming the amp
My Crown CTS Power Amp has a broken on off switch how do you open the case to get to the switch?
Hi Ed, I sent you the link to download the user manual of the CTS600 and CTS1200 Crown amplifiers
I hope ter serves to repair your Crown power unit
Greetings Franco Dosil
Hola Ed, te envio el link para que descargues el manual de usuario de los amplificadores Crown modelos CTS600 y CTS1200
Espero ter sirva para reparar tu unidad dee potencia Crown
Saludos Franco Dosil
https://data2.manualslib.com/pdf5/106/10592/1059159-crown/cts600.pdf?48095c310cea414e22394c5d55bb60d2&take=binary
https://www.crownaudio.com/en/product_families/cts-series
https://www.crownaudio.com/en/products/cts-600
3answers
Crown xli 2500 service manual needed .
Not most service manuals can be downloaded unless you use a model close to the original.
Try service manuals.com
Crown cts 600 3pin int to be 1/4 female guitar input
Do you mean that you would like to change from a 3 wire cannon plug to a 1/4" female?
How do i change the fuse in my cts 600 amp
Try pressing the Reset Button, if that does not fix it take it to the repair shop. If you do not have experienc you can do a lot of damage.
Input 60Hz hum
i had the same problem once and in my case i had accidentally used ground wire for signal. pls check ur connections again. one check u can do is set the high pass filter to 70Hz and see if that cuts out the low hum.
Blinking red fault warning
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Mike Cairns
Mike Cairns
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
