To enter the MOD( function on the command line:
Example: MOD(278,9)=8
An alternative way is to use the Catalog.
SOURCE: i do not know how
Hey it is. Okay, so start with a equation: say, y = -(1 |x|). Now type y = -(1 , then press the [OPTN] button, next to the shift. Next press the [NUM] button or F5. The first menu button should be Abs or absolute value. When your done it should look like this. y = -(1 Abs (x)) then graph it.
SOURCE: binomial function in calculator fx-911ES
The binomial probability distribution is defined as
P(r;p;n) =(nCr)(p^r)*(1-p)^(n-r)
where n is the number of trials, p the probability of success, and r the expected result.
Let n=20, r=7, p=0.15 ( I do not know wether this exemple has any meaning in the context of your problem, but you have to enter values that mean something to you. I am only showing you the key strokes
To enter 20C7 you press 20 [SHIFT][nCr]7 ;
To enter 0.15 to the power 7 you type 0.15[X to ] 7 the key is between
[x²] and [log]
To enter (1-0.15) to power 20-7, you type 0.85 [X to] 13
With [*] standing for multiplication key , and [X to] the raise to power key, the exemple above can be entered as
( 20 [SHIFT][nCr] 7) [*] ( 0.15 [X to] 7 ) [*] ( 0.85 [X to] 13 ) [=]
Here is a screen capture to show you what it looks like. However on this calculator the combination 20 [SHIFT][nCr] 7 is represented as nCr(20,7).
Hope it helps
SOURCE: how do I calculate normal distribution using a
I don't know about fx-9750gII, but for fx-991MS
Change the mode to REG
Then
Shift->3(DISTR)->1(P())->give your Z value
SOURCE: How do you use a fx-9750GII calculator and inverse
One not way would be to define a 4x4 matrix Mat A to hold the coefficients of the linear system. Then define a 4x1 column vector Mat V to hold the constants on the right.
Define a third 4x4 matrix Mat B you may leave filled with 0.
On command line, in Run Mat screen enter (Mat A) ^(-1) and store it in the zero-filled matrix Mat B. this is the inverse of Mat A.
If the inverse of Mat A exists, and it does in this case, the solution of the system is obtained as the column vector, resulting from the multiplication of Mat B by column vector Mat V
You can even shorten the procedure by just calculating ((Mat A)^-1)X (Mat V) [EXE]
To summarize
To get the Mat identifier on command line,
To calculate the inverse of the matrix just use the [SHIFT][)] key sequence which is (X^-1)
Multiplication operator is the regular [times] key.
SOURCE: CASIO fx-115ES I need to calculate
Actually, the answer is 79.
The fx-115ES does not have a key for the modulus operation. Nor does it have an integer-part or fractional-part operation. However, it is possible to calculate the remainder using integer arithmetic.
Press MODE 4 to shift into integer mode. Then type in 3 5 2 - 9 1 * ( 3 5 2 / 9 1 ) = and see the answer 79. It's a pain as both numbers have to be entered twice, but it does get the job done.
To get back to working with real numbers again, press MODE 1 ( or MODE 2 for complex).
