Hi, I just bought a second-hand Nikon D100 and I found out that all photos have a defect mark, as a piece of hair, appearing in the picture, as you can see here: http://dl.dropbox.com/u/1527741/DSC_1369.JPG What could be the problem?
Hm, the photo doesn't work properly, could you re-upload it? And did you check the manual for your specific device? If not, you can find it here: Nikon D100 PDF Manual Download
SOURCE: Nikon d100 issue....
make sure you have card inside, your lens if fixed correctly and your lens aperture by the end max 32 or 22
SOURCE: NIKON D2H ERR FAULT
I had a D2H with a similar error. The camera started giving an 'ERR' message almost from new but from reading various posts from other users I assumed it was a 'known' idiosyncrasy of the D2H, the camera would create an underexposed first shot after turning on. A colleague has the same problem on his D2H, and there are numerous references to the same problem on the web. Your post points to a similar shutter issue. My shutter failed completely at around 65,000 actuations, well short of the advertised '150,000'. In addition, the horizontal Main Command Dial had also failed a short time before, and it had cost me £135GBP to have that repaired.
The problem is down to the shutter and unfortunately replacing the shutter costs £349GBP in the UK, quoted to me by the Nikon UK Service Department, in Kingston, in March 09.
As for Nikon repairing it under a 'goodwill' policy, you may have better luck than me if you live somewhere other than the UK. I told them to keep mine, as attempting to charge me for the repair was the last straw, it wasn’t worth me spending another £350 on a camera that hadn’t been reliable in the first place. I had been planning on getting a D3 in October/November but will now probably sell my Nikon gear and go over to Canon, as Nikon don’t seem too bothered about their professional user base, and I certainly won’t be paying £5,000 for a D3X.
SOURCE: NIkon coolpix L18 horizontal lines appear after taking picture
contact NIKON BAD CCD PROBLEM !
Get ir repaired free of charge just call them thousands face the same problem and all brands are repairing it free go call them
see the link for widespread Bad CCD problem dont worry if u are not on list but u have the same problem call them PLS RATE ME FIXYA for help !!
http://www.imaging-resource.com/badccds.html
SOURCE: D70 doesn't appear on Mac desktop
This is easily solved.
Most probably the camera's USB connection mode is set to PTP. This is useful for certain situations such as controlling the camera from the computer (you even take photos from OS X's built in Image Transfer).
Change this to "Mass Storage" in the camera settings menu and your camera will behave just like a card reader. Next time you connect it to the computer, plug it it, then turn it on and it will appear on the desktop and in the sidebar as an attached drive.
Don't forget to eject it before disconnecting just as you would an ordinary external drive.
SOURCE: My Nikon D80 is not Auto Focussing and 'r11' keeps appearing.
Try cleaning the lens contacts with alcohol or sprit
