ON RADIO SCREEN SHOW SECURE
If you need the code for your Nissan radio contact this link and pay a small fee for them to retrieve the code for you: Car radio codes in Uxbridge London Gumtree
My car radio broke in my Nissan almera year 04 my friend gave me one but says secure on it and way to get it working
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Nissan servicecentre and get them to enter this code for you.
SOURCE: P reg Nissan Micra radio says ''secure''. I cannot enter code.
Either the code you are using is not correct or your method of entering it is incorrect as your radio is not recognising the code..
To reset it from SECURE, leave it SWITCHED ON ...UNDISTURBED for as long as it takes to automatically reset itself . Could be many hours ....but normally only an hour or two.
If you want to check that you have the right code then POST ANOTHER QUESTION quoting the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Testimonial: "good prompt answer tho' still not sure of initial procedure that caused immediate problem"
SOURCE: 2000 Mitsubishi Galant ES need radio unlock code
Sorry.....This code will only be available from your Main Dealer.....or by a Radio Decoding Service who will "read" the code inside your radio using a laptop
SOURCE: the radio in my nissan micra is locked
Remove the radio from the dashboard
Post the radio Make+ Model plus ALL the letters+numbers on any labels , barcodes or engraved in the metal casing
SOURCE: bought r reg nissan micra last week but no code
There should be a RADIO code in the owners handbook ,,,,,, if not it's the local deealership for you and they will enter the manufacturers code for a small fee. (cheaper than a replacement radio ! )
SOURCE: hi there i wonder if us can help ...i got a nissan
It is showing SECURE because wrong codes have been entered previously
To restore leave SWITCHED ON...UNDISTURBED for as long as it takes to automatically reset itself.
Make sure you have the correct code.
You can get an unlock code here: https://radiocodevault.com/nissan/
