I have a whirlpool Gold Quiet Partner Gold and when I turn on to wash, the timer says 81 minutes, it runs for a long time and goes to 71 min and runs and runs and runs. It will go down to 47 min and again will run and run. It doesn't seem to get hot like it used to and dishes are wet when all done.(It can run for hours) Thanks
Hello
The heat dry button must be lit up or you are using air dry instead!
ican
Please leave a rating before you leave
It tyrned out to be the heating element
I have the same problem with the dishes not drying well, but the GU1500 does NOT have a dry signal light, so how do I know if it is supposed to heat dry or not?? The only lights on my GU1500 are soaking, water heating, clean and sanitized. The other models (i.e. Gu1100, GU1108, GU1200, Gu2300, GU640, DUL300) ALL have a drying light. So, is the gu1500 supposed to heat dry?? If not, what is the heating element for?
