OVERLOADED AND THERE IS NO RESET BUTTON
SOURCE: I purchased a black and decker 100 watt power..cant register it!!
http://www.blackanddecker.com/MemberCenter/ is the new site. Enjoy!
SOURCE: how do I replace the fuses in a 750 watt black and
look for a cover to maybe flip up or slide (most inverters fuses are coverd)
SOURCE: How do i tell when the inverter is charged?
Question does not seem to match this inverters capability.
INFO:
This Power Inverter converts vehicle’s 12-volt DC power into household 115-volt AC power. AC and USB outlets power and/or recharge personal electronics.
We have owned one of these Power inverters for over a year now and have run a great deal with it, from TV to drill press PC and any thing that was small and that could run from my car. Very nice product.
SET UP: Connect wires. ensure correct polarity, push button on top. Plug in 110 volt appliance.
Hope this tip was of some use.
R/
David
SOURCE: 400W Black & Decker Power Inverter Doesn't Power My LCD TV
The problem of your inverter is from
your battery .your laptop and dvd
player requires little current to
operate.But you tv requires more power
to run, if your battery is low you it will
not last for 3 minutes. If your battery
has a low current rating, it will also be a
cause, for example, if it is below
100ampere hour. Lastly if your battery
is bad i.e. if it reads below the
stipulated dc voltage Require by your
inverter to operate.
SOURCE: I just bought a power inverter for use with my pc.
There are two possibilites: the first is the over 400W power draw, the other is how you have the inverter connected. Do you have the inverter connected directly to the battery terminals (the clips) not the outlet plug (cigaretter lighter)? This is needed for any load over 80W and under 400W. (the inverter can handle a load demand over the 400W limit but only for short periods (800W).)
What is the load that your PC pulls (Is it a laptop or a desktop)? The laptop in my home has either a 65W or a 90W load (depending on the battery and the AC adapter we are using). Desktops take much more power (usually).
I hope this helps.
