Dozens of models to choose from. All questions on Fixya need 'make model (what it is)' as the first 3 words.
Here are some guesses. The 'control cover' is where you put the back-up battery.
To change the 12/24 hour time format, open the CONTROL COMPARTMENT COVER on the bottom of the clock and adjust the 12/24 TIME FORMAT switch to the desired format .
https://manuals.brookstone.com > ...
PDF
Features: x WWVB Radio Controlled Clock (Atomic Clock) x Time in 12/24 hour format x Manual time setting option x Time Zone setting: +/- 12 Hours from GMT.
People also ask
How do you convert a 24-hour clock to a 12-hour clock?"); display: inline-block; height: 24px; width: 24px;">
How do I change my alarm clock to 24-hour clock?"); display: inline-block; height: 24px; width: 24px;">
What is 12.30 pm in 24-hour time?"); display: inline-block; height: 24px; width: 24px;">
Feedback
Here are the instructions for changing the clock from 12 to 24 hour and back.
12-Hour, 24-Hour or Clock Black-Out Your control is set to use a 12-hour clock. If you would prefer to have a 24-hour military time clock or black out the clock display, follow the steps below.
Press the BAKE and BROIL HI/LO pads (on models, use the upper oven controls) at the same time for 3 seconds, until the display shows SF.
Press the CLOCK pad once. The display will show 12 hr. If this is the choice you want, press the START pad.
Press the CLOCK pad again to change to the 24-hour military time clock. The display will show 24 hr. If this is the choice you want, press the START pad.
Press the CLOCK pad again to black out the clock display. The display will show OFF. If this is the choice you want, press the START pad. NOTE: If the clock is in the black-out mode, you will not be able to use the Delay Start function.
Selecting 12- or 24- Hour Mode While in the Time screen, press or to select either 12- or 24-hour mode. If 12-hour mode is selected, PM displays for the afternoon/evening hours. AM does not display for the morning hours http://origin-www.brookstone.com/webassets/pdf/740687p_manual.pdf
I'm sorry for the difficulties you're experiencing in getting the Manual of the Dream Machine. Please click hear to download the Manual. Please see the below instructions to set the Clock.
Thanks for using Fixya. Please let me know if you require any additional help.
I feel your pain, I am in the same position. After endless mucking around I finally figured it out. By the way, this is for my model P10034AP.
Press these buttons: -
Cancel [to abort anything currently underway]
Clock [to set the time]
Cancel [to clear the time allowing input]
nnnn [the 4 numbers HH:MM in 24 hour time]
Clock [to set the new time]
Hope that helps :)
Cheers Jonathan Barton
I have the same problem. I used in on a trip to Europe and plugged it in on 220v. Now I have to replace the power adaptor and I took it to 3 different repair shops. They all told me thye needed to know the specification of the power adaptor, like output voltage and mA in order to change it. But these info are not specified on the adaptor like it should. So I spoke to a sony representative over a online chat and she told me the adaptor doens`t come with the speaker, it's not from sony and they do not have this onformation I needed. So we tried with a 500 mA 3v and the clock was showing but there was not sound, the ipod was not being charged, etc. So we changed it to a 900mA and 6v. It works now! Well, I don know if these are the right specification but everything is working perfectly. I'm just not sure if it can get damaged after a while if these are not exactly the right voltage and power.
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
