car is only two year old
wont select reverse of revs out in reverse?
module says std automatic and not a CVT transmission
when a module goes into fail safe you always have reverse and third
check oil level first
wont select
check shift cables or linkages adjustment shift stick alignment
revs out
more likely a solenoid or mechanical failure
if there is a bang as you shift into reverse its the oil pump
if none of the above are the cause
could be the module ......not sure on that
