Question about Exercise & Fitness
How to safely move a freemotion x3 incline trainer to different location
Just purchased a gently used Freemotion x3 incline trainer and need to know how to safely disassemble so it can be moved.
  • Tina Steinbach Jul 11, 2012
    This model treadmill Freemotion X3 incline trainer does not fold up, and need to know safest way to move it from a tight upstairs space and will not fit down the stairs fully assembled.
    Top Expert:
  • 12,223 Answers
Please the video and proceed according:
God bless you
Posted on Jul 11, 2012
  • ernesto cuadra
    ernesto cuadra Jul 11, 2012
    download the instruct.manual from www.fitness.manualsonline.com or www.iconservice.c om and follow the instruction how to dissasembly, and ready.
    God bless you
2 Suggested Answers
SOURCE:
bwinton
  • 83 Answers
SOURCE: Freemotion treadmill incline not going all the way
The problem is either in the lower control board or the lift motor. I would start by replacing the lift motor. Then if that does not fix it, replace the lower control board.
Posted on Apr 29, 2010
How do I purchase a manual for my FreeMotion 330R ??
First, try Googling (FreeMotion)(330R)(manual) without parens.
May 30, 2017 | FreeMotion Exercise & Fitness
Tt30 is stuck at 3% incline and will not speed up or slow down. It also beeps continually and displays SB for about 5 seconds when first turned on. I tried the recalibration procedure and it does not...
please RUN the software calibration for easy diagnostic and fix it.
go to HOOD cover motor, and follow the steps, or ready your owner manual
God bless you
Oct 15, 2013 | FreeMotion Tt30 Incline Trainer
My tension is very loose when I do freemotion quilting. It is fine on the top, but the bottom gets tangled. It sews fine when I have the walking foot on, but when I put on the different plate for...
Hi Leann: Think about how a sewing machine works. Now think about what kind of difference an 1/8th of an inch distance would make. Yes. You will need to adjust your top tension when you do free motion work. Keep in mind that plate is not just stopping your feed dogs from working... it's holding your materials that far away from the bed of the machine... so when the thread makes a loop and tightens for the stitch it has the extra 1/8th of an inch to make up for... if the tension isn't right... you got loops. There are no "specific" settings for tensions... you learn by doing you stitch a few stitches on like materials and tighten until you see a good stitch.
Sep 29, 2013 | Janome 1600P-DB Mechanical Sewing Machine
Freemotion XTE Elliptical display won't turn on at all
please test the battery by new ones, clean the contacts batteries and replace . test the reed switch see the diagram attached. However you must download from www. fitness.manualsonline.com
God bless youc719c602-5572-4506-9d14-437751e71106.gifc3db8187-db09-41b3-90bb-d7e9652e1ebf.gif
Jun 04, 2013 | FreeMotion Fitness xte Elliptical Trainer
Incline not working
The Trainer is reading; Serching for motor controler
Sep 09, 2012 | FreeMotion I7.7 Incline Trainer Treadmill
We have a Free Motion Tt30 Incline Trainer making a loud noise that sounds like a bearing going bad, then the noise stops. Do you have any repair suggestions?
1) Lube the machine see the video and use the common sense, this happen because the lack of maintenancae according with the instr. manual. Shut down the machine for to protect the electronic system.
2) Lube the rollers bearing too, very well.
3) Test the input voltage motor, if there are the motor NEED repair.
4) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram.
God bless you
Sep 06, 2012 | FreeMotion Tt30 Incline Trainer
My treadmill belt doesn't move at all
Contact the seller for help or send it back if it's only a month old, it must be under warranty.
Jan 25, 2012 | FreeMotion Exercise & Fitness
I need an owners manual for my freemotion tt30 terrain trainer treadmill
E-mail
customercare@freemotionfitness.com (I found it on the FreeMotion website). I needed one too, and they just send me a response with a pdf file of the manual. Hope that helps!
Nov 20, 2010 | Computers & Internet
Apr 06, 2010 | Icon Exercise & Fitness
Exercise & Fitness Logo
191 people viewed this question
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
