Question about Maytag 24 in. MDB3700 Built-in Dishwasher
Maytag Dishwasher no workie Model# mdb4040aww
I just got a house and inherited the dishwasher that came with it. I turned it on, at least I tried to, and it won't do anything but light up. Can anyone help? Thanks
SOURCE:
SOURCE: Mouse inside dishwasher
I have put steel mesh over the plastic mesh which I got at the hardware srore, and it fixed the problem. the mice are getting in through an exterior hole in your house. Use coarse steel wool to plug any holes or cracks larger than 3/8 of an inch around your house. How much did you pay for your dishwasher unit?
Posted on Feb 17, 2007
SOURCE: cleaning out dishwasher
Hi I checked the manual on line. Here's what it said.
Dishwasher has an odor
Run dishes being held in the dishwasher through a Rinse Only cycle.
• Many dishwashers have a “new” smell when first installed. This will dissipate with use.
• Dishwasher may not be draining properly. (See “Dishwasher Will Not Drain” section.)
• For a strong odor, place baking soda in both sides of the detergent cup. Select Light
Wash cycle and allow the water to circulate for about 10 minutes. Interrupt the cycle
by unlatching the door and let it stand overnight. Restart the dishwasher by latching
the door and allow it to complete the cycle. Another alternative is to use a dishwasher
cleaning product such as Jet-Dry Dishwasher Cleaner*.
Good Luck
Posted on Jan 06, 2008
SOURCE: Maytag Dishwasher
THE 3 SEC LIGHT WILL NOT SHUT OFF AND WE CAN NOT RUN THE DISHWASHER
Posted on Sep 21, 2008
SOURCE: Maytag dishwasher won't start
"unlock" the machine by pressing on '3' and holding for a few seconds. Thats what it says on the back of my dishwasher which is the exact same model.
Posted on Oct 28, 2008
  • 172 Answers
SOURCE: My Maytag dishwasher does not drain water after the wash cycle is over
Hi olabrk,
If you have a disposal make sure it is clear. You can put some icecubes in it to clean the blades and run some water through to make sure the drain is clear. If the dishwasher will still not pump out all the water check the drain line from the dishwasher to the sink drain for obstructions. If the drain is you will have to check the pump for obstructions. Sometimes glass, popcorn, toothpicks etc.... can get in the pump and prevent it from pumping out. If the pump is clear, then you will need a new pump. Good luck to you.
Mike Anderson
Posted on Oct 30, 2008
Extremely heavy limescale residue on all items after dishwasher has finished. water temp in house has been turned down. Had water tested by city water company and results were clear. 12 months ago maytag...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Mar 24, 2011 | Maytag 24 in. MDB4651AWS Stainless Steel...
Trying to determine its age
Only from the manufacturer you can find. If you can note the Model No Sr. No of the machine, it is possible. If it is a discontinued model, it may not be possible.
May 20, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Maytag mdb3700awx dishwasher doesn't turn on
check the house power supply to the dishwasher. If that isn't the problem, replace the switch control, part # 99001611
Nov 12, 2009 | Maytag MDB7100AWB Dishwasher
Water will not drain out of dishwasher
I would remove the drainhose from sink and try draining in to a pale.if it does not then you will need to remove drain hose and clean out.Also you may need to clean out all screens in pump just remove with torx screwdriver easy when you get into it
Mar 12, 2009 | Maytag MDB9600A Jetclean II Built-in...
My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Jan 29, 2008 | Smeg 24 in. DWF612WH Free-standing...
Maytag Dishwasher
we have a model mdvtt53aww1 and you can push three buttons and will light up the hi temp wash, heated dry and sanitize is there a code make it start
Oct 01, 2007 | Dishwashers
Knob wont turn - have to turn it manually!!!
Emsie, the model number posted has a electronic control so Im not sure where we are going with this. A couple of things to check. Some models have what they call a foam guard routine. This can cause the machine to stop several times during wash because of oversudsing. (too much soap). You want to make sure the water temp going is is at least 120 to 150 degrees. The heater will only raise the water temp 1 degree every 4 or 5 minutes. This can cause long cycles. You might have a bad timer. If you remove the toe panel there should be a tech sheet attached to it. This will give you good information on your dishwasher opertaion...Catriver..post back.
Oct 28, 2006 | Maytag MDB9600A Jetclean II Built-in...
Maytag 24 in. MDB3700 Built-in Dishwasher Logo
Top Maytag Dishwashers Experts
Mike
Marvin
Marvin
Vitally Alcher
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
