Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Posted on Oct 25, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool ultimate care II quietwash filling with water during spin cycle
My Whirlpool Ultimate Care II Quietwash washer fills with water during the spin cycle. This happened a few years ago and I replaced the inlet valve. I tried doing this again and the washer worked for several loads before doing the same thing. Is there any other part I should try to replace or is this just a defective inlet valve. Any ideas?
keith jones
Level 3:
Master:
  • Whirlpool Master 747 Answers
  • Posted on Oct 26, 2017
keith jones
Whirlpool Master
Level 3:
Master:
Answers
747
Questions
Helped
314698
Points
1478
Sounds like the valve again
5 Related Answers
Anonymous
  • 481 Answers
  • Posted on Jul 15, 2008
SOURCE: Whirlpool Ultimate Care II Plus Washer Model: LSQ9264HZ0
if you hear the motor running while it is supposed to be agitating or spinning then it is most likely the direct drive coupling between the motor and transmission.43f18ab.jpg9bd1c44.jpg if you already checked this and think it is a different problem then let me know, i will help you figure it out.  Mike
Anonymous
  • 1136 Answers
  • Posted on May 16, 2009
SOURCE: Whirlpool washer ultimate care II sometimes does not spin.
HI It sounds like the spin basket drive is going bad. If it was the lid switch, you would get no sound. Let me know if I can assist you further.
Thanks
Vic
Anthony Abbott
  • 136 Answers
  • Posted on May 29, 2009
SOURCE: does not spin or empty
it might be jammed or there might be dirt or some sort of a clog. I would suggest you clean it out.
honeymokey
honeymokey
  • 3113 Answers
  • Posted on Jun 18, 2009
SOURCE: Whirlpool Ultimate Care II washer fills with water and stops
Lid switch. Push down on lid.
Anonymous
  • 116 Answers
  • Posted on Aug 02, 2009
SOURCE: whirlpool ultimate care II stops after filling
Hi, could be faulty timer, faulty water level switch, faulty start capacitor for motor, or faulty motor. always put clothes in machine before starting. you can empty machine by lowering drain hose to flow level.
1helpful
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Whirlpool Ultimate Care II keeps taking water.
ck your drain nose/drainline, chances are you have along hose, perhaps even draining along the floor behind hte unit, into a "closed" drain system. in which cawee the wwater is syphoning out during the rinse cycle, youlll needt o raise the drain hose to above 48" and have it drain into a stand pipe to prevent siphoning effect
sounds like a broken coupling.
it probably don't agitate either.
Washer will not Spin during SPIN CYCLES
Thanks for the question If your washer sorta spins and washes ok, your problem is with the transmissionTHanks for your question THe Appliance doc
Whirlpool ultimate care II stops during cycle
THe most likely cause for this is either the lid switch or the timer itself sticking.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
