My Cuisinart coffee maker heats the water, but does not flow out of the coffee filter. I have hot water in the filter, but it will not drain into the coffee pot. You can hear and see the heating element working and then shortly after the finish beep and light go on and the coffee maker turns itself off.
SOURCE: Cuisinart Grind and Brew will not emply all the water
The two most common reasons for overflow or underflow have to do with the carafe lid and the filter basket - they key to smooth flow with this coffee maker is making sure the filter basket and carafe lid are making the proper contact with each other so that the center knob on the carafe lid pushes slightly up on the filter basket spring. Make sure the carafe lid is completely closed. Make sure the filter basket is pushed all the way down. Make sure you are not using the gold tone filter and a paper filter at the same time. For some reason, I get better results when the handle of the carafe is resting against the right side wall. If everything is in place, I would suspect a problem with either the filter basket being clogged or some problem with the carafe lid - call Cuisinart as they should be able to order these parts for you.
SOURCE: Cuisinart Coffe Maker has no power
Talked to Cuisinart tech support today and they told me to unplug and leave it for 2 hours... that resets it to the factory defaults. Worked for me...
SOURCE: Heating Element Shuts Off Very Early
Reset the timer for shutting off the hot plate, instructions are in the user manual.
SOURCE: After the machine beeps "ready" the filter is still full of water
Make sure the lid is on the caraffe, or else it will not make the proper contact with the filter basket (and hence the filter basket will be forced into the closed position).
SOURCE: My cuisinart cofee maker is clogged. Water goes
If you pull out the plastic stem on the back left side, you can access the filter at the bottom. The filter can be popped out of this piece, washed and replaced.
