Logitech USB HEADSET H390 Logo
Posted on Jul 10, 2012
Logitech headset usb wiring diagram?
I've broken the 10 wires connecting the headset to the USB circuitry. Couldn't find any wire diagram to resolder them back. From the broken soldering i can get very limited informations on colors. Any help? If someone reading has this headset model (or one similar), could you open the plastic covering of the usb plug and answer me back with the color coded wires - soldering point correspondence? wires from the headset are in three bundle of 3 + 2 + 5 wires. Wire color are copper (3), red (3), green (2) blue (1) and green/red (1). the headset has a mic. any help would be greatly appreciated. Matteo
  • 3 more comments
  • Antony Stephens
    Antony Stephens Sep 20, 2014
    Someone posted a couple of pics of the H390 board with the wires. Its not a clear enough picture for me to see so who ever posted them can they please repost with better images of a higher resolution pretty please. BTW here are the two images.
  • Aremdms
    Aremdms Apr 07, 2017
    The provided pictures are not for this logitech headset model. Mine H390 has 5 soldering points in both sides. Can anyone provide a picture of correct way of soldering those wires?
  • paltusrba
    paltusrba Sep 24, 2017
    Hi! from Russia with love. it's from h960 but it's the same i hope
    logitech h960 a-00053 usb headset
  • Anonymous Feb 19, 2019
    could at least be a picture in a resolution we could read...
  • Anonymous Aug 12, 2023
    This image is completely unhelpful.
matt
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 27, 2014
matt
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
9316
Points
Is this what you are looking for?
  • 3 more comments
  • matt Feb 27, 2014
    photes
  • Antony Stephens
    Matt if these images are of your own headphones could I trouble you to take a higher resolution image please or let us know what cable bunch the wire colours come from please? the only one I know is that the blue one is on the first image second from the bottom (tag 3)
  • Antony Stephens
    ho and comes from the black wire group
  • paltusrba
  • lucio magno
    lucio magno Nov 18, 2018
    Hey guys. Is tgere any possibility to send a better resolution photo (of the wiring diagram for the h390)? I am trying to fix mine but the resolution on the correct photo is horrid...
2 Related Answers
Anonymous
  • 33 Answers
  • Posted on Feb 16, 2008
SOURCE: USB ripped off
Here's one
drifterK
Catalin Turcu
  • 4924 Answers
  • Posted on Oct 26, 2010
SOURCE: I have a Logitech H555 Headset that I need to fit
just plug the jack into the exit of the computer or whatever device u use...and than from the balance turn on just the right channel...tide the ground one ...than try one by one until you figure out which 2 wires makes the right speaker sound...the other 2 will be the left ..
Logitech mouse left button does not work
That is a circuitry problem. You can try this following procedure if you can. --unscrew and open your mouse casing. --you need a tester (VOM) to test the wiring continuity. If one of the wire is open connection you can replace it with a new USB or PS2 connector. If all the wire is shorted, proceed to the next step. --Check if the microswitch is ok by testing the pin connection using the tester. Microswich has 3 pins, test only the soldered pins. When you press the switch, it might be shorted. If not, replace it with a new microswitch.
Microswitch and USB/PS2 connector are available in all electronics shops.
The usb port is loose. that is why it wont work
If it in Worranty Period, Contact Service Center of Logitech.(Recomanded)
Can i repair the cable on my headset myself. their is a short in the wire and no sound out of the left side Logitech USB with in line volume
problem is lately all the higher end headphones and usb sets use microthin wires. there is fine strands like as thin as a string and woven into it is 2 or 3 micro thin copper strands. it may be possible but very difficult...
I have a short wiring in my left ear cup of my Logitech Wireless PRO USB Headset, and sound out of that ear shorts out all the time.
Time for a new pair. If you are not handy with a sodering iron it is best to buy another set. Once the wires are broken inside the insulation the only thing that can be done is replace the wire itself. it is easy to break the wires inside the insulation twisting the cord, pulling or yanking the cord, along with blending the cord in a sharp bend acn damage this cords that they put on products today.
Logitech USB Gaming Headset only working out of one ear
I've had this happen twice with Logitech headsets and believe it has to do with the cheap/fine wire they use in the cables. I suspect that a good tug on the cable will snap the wire or some other internal connection.
1helpful
Emachine t1840 wiring diagram power switch wire to mother board ?
Because there are so many different case and motherboard combinations sometimes it can be difficult following the instructions for connecting the front panel, USB header and audio header.
Below is a few generic guide that should stop some of the confusion with the labels on the wires.
Front Panel Audio
***Please note this is a generic wiring guide and we can not guarantee it will work with every motherboard. Please check your motherboard manual first. Wiring the headers wrong can cause damage to the motherboard and case, this damage is not covered by the warranty***
another handy USB wiring guide can be found here http://www.directron.com/installusb.html
this maybe easier to follow
FRONT PANEL AUDIO
2________10
__
1________9
Pin Wire
1) Mic In
2) GND (ground) or if 2xGND available, it’s the GND for the headphones, NOT the Mic
3) Mic BIAS
4) n/c
5) Speaker Right Out
6) Speaker Right Return
7) n/c
8) no pin (n/c)
9) Speaker Left Out
10) Speaker Left Return
n/c = not connected
USB (F_USB1 and also F_USB2)
2________10
 x
1________9
Top row of pins
2 = USB port 2 : VCC/Power/+5V
4 = USB port 2 : Data -/D-
6 = USB port 2 : Data +/D+
8 = USB port 2 : Ground/GND
10 = USB port 2 : pin present, but not connected to anything.
Bottom row of pins
1 = USB port 1 : VCC/Power/+5V
3 = USB port 1 : Data -/D-
5 = USB port 1 : Data +/D+
7 = USB port 1 : Ground/GND
9 = USB port 1 : no pin present
Front Panel Connector (FP1)
1 2
x 
9 10
1 = no pin present
3 & 5 = Power Switch
7 & 9 = Power LED (light)
2 = pin present, but not connected to anything.
4 & 6 = Reset Switch
8 = 10 = Hard Drive LED (light)
3helpful
4answers
Left headphone stops working
Probably a broken wire, try to isolate where it is at & then cut the wire, strip it back & re-connect & tape it up. To isolate where the break is hook up your headphones & pull, push & twist the wire all the way up to the ear piece till you find a spot where it cuts out or comes on & there is your broken wire.
1helpful
Apparent broken wire issue
I somehow think that it may not be the headphones, but rather the hardware in the computer...but then again if they are under warranty definetely get them fixed(if they are broken?...)
Good Luck!
1helpful
Broken wire to my microphone on my lifechat lx-3000
You cant wire then directly there is a USB D-A chip that controls the headset converting to 1/8" mini plugs may work one for the mic and one stereo plug for the earcups
Top Logitech Radio Communications Experts
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
